Old 11/29/11, 7:06 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is online now
Default Roof ridge caps
On this newer ridge cap it appears there is a nailer shingle under each ridge cap piece. The problem is that there is an exposed area which would allow for high winds to rip the ridge cap off because it does not sit flush and they are not adheared to the shingle below. They are very easy to raise after a year of installation.
Has anyone seen this before it is a first for me.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/29/11, 8:40 AM
Sean Fogarty's Avatar
Sean Fogarty Sean Fogarty is online now
Default Re: Roof ridge caps
Looks like an actual ridge cap shingle. Most never use them because its easier and cheaper to rip 3 tabs down. They usually are wind rated to some extent but the manufacutrer would provide more info.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 11/29/11, 9:07 AM
Robert W. Jude's Avatar
Robert W. Jude Robert W. Jude is offline
I agree that you should research the manufacturer's installation instructions or recommend your client do that
Old 11/29/11, 10:42 AM
I did research it, but it says to be installed down wind. How the hell can you do that on a hip roof in Florida!
Donate here:
Melbourne, Fl 32901
Old 11/29/11, 12:11 PM
Dan Curtin Dan Curtin is offline
I would suggest each one to be sealed down with roof cement
Old 11/29/11, 8:09 PM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
I have seen it before. Usually when a roofer cuts a dimensional shingle to make a ridge cap. I would also just recommend adding shingle adhesive.
or bubble gum
Of course my disclaimer would say that all repairs should be performed by a licensed contractor and they should further evaluate and repair as needed. I never put how-to repair something in writing as an inspector. I do make some recommendations verbally though.
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 11/29/11, 8:36 PM
Aubrey J. Kahn Aubrey J. Kahn is offline
Dan, you hit the nail on the head, or not. You are absolutely correct, many cap shingles do not have that adhesive strip which would seal it to the shingle underneath so a little roofing cement will do the trick. This and price is why many roofers will cut down 3 tab shingles to use them as ridge shingles.
Old 11/29/11, 8:58 PM
Ridge caps made with 3 tab shingles are made by cutting full-lenght shingles at the tab cutouts.
They need to be trimmed back at the ends of the caps by 1", this allows better contact to the adhesive strips and allows it to settle down at the corners.
The photo shows otherwise.
You can also get enhanced profile hip and ridge caps from the manufacturer.
Old 11/29/11, 9:12 PM
Would these qualify???
Just a little roof cement!
865-256-5397
Old 11/29/11, 9:22 PM
Jeffrey R. Pope's Avatar
Those are actually pretty common here in CA. They are just as you said - designed specifically as ridge caps with a fold to cover the fastener. They are designed to be "self-sealing" after they've been fastened.
Generally, they will last about 10 to 12 years before needing to be replaced. I don't know how well they would hold up against Florida storms.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/29/11, 10:22 PM
Thanks to all for their input!
Donate here:
Melbourne, Fl 32901
Ridge vent end caps jtroth Exterior Inspections 2 10/13/10 9:49 AM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
Moss growing on roof ecox1 Exterior Inspections 45 1/19/06 9:57 PM
