Old 10/31/08, 10:29 PM
Keith Swift, PhD. Keith Swift, PhD. is offline
Default Scary Cracks
It’s Halloween, so I want to talk about things that can be scary: cracks. We all know that houses move and produce cracks, even new houses, but I want to talk about cracks that are scary. The cracks that you’re looking at in the first picture were produced by moisture from a deteriorated waste pipe that caused expansive soils beneath a slab-on-grade house to swell and move the house—one might even say, naturally. However, this movement could have been predicted on the outside by fissures in the soil, shown below, that are typical of expansive soil. The moral of the story is this, make sure that you’re knowledgeable about the soils in the areas that you inspect, and if you see any evidence of movement—even repaired stress fractures, recommend a second opinion. In addition, ALWAYS recommend that sewer pipes be video-scanned. Happy Halloween everyone.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI
Old 10/31/08, 10:54 PM
Default Re: Scary Cracks
Always do--always have. Several have been found to have become completely separated under the house structure or in a difficult area in the yard. Gives the buyer something to think about!!
Old 11/1/08, 10:14 AM
Michael R. Boyett's Avatar
Do you have standard wording for your sewer pipe video-scan advice? Mine says the following but I'm open to suggestions:
Note: This visual only inspection cannot ensure the integrity and performance of underground or hidden water or waste lines. The client should consider having the waste lines video-scanned for integrity by a qualified contractor.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 11/1/08, 6:19 PM
I actually have a fairly long narrative that prints without being selected and describes the many different waste pipes relative to their age, and how my evaluation is confined to specific fixtures, sinks, toilets, etc. Then, I select from several other narratives that identify specific waste pipe materials--cast-iron, glavanized, ABS, etc. Following this selection, I have 12 different and specific waste pipe narratives that I can select from and edit as I see fit. The first, and most commonly used, appears with "ACTION REQUIRED," in bold, red, capitals, and reads:
If the sewer pipe has not been replaced or recently video-scanned, I strongly recommend that you arrange to have it scanned. It cannot be seen and its condition can only be inferred, and all sewer pipes can be compromised by corrosion, roots, and soil movement, and blockages are not only common but sometimes cause sewage to back-up into residences."
The unspoken message being, of course: "Don't call me when the sewage hits the fan."
Old 11/1/08, 6:27 PM
Excellent...thanks Keith.
Austin, Texas
(512) 577-2579
Old 11/1/08, 7:03 PM
Keith, this is what I have, is this adequate or should I use yours. ??
Waste and drainpipes pipes are equally varied, and range from modern acrylonitrile butadiene styrene [ABS] ones to older ones made of cast-iron, galvanized steel, clay, and even a cardboard-like material that is coated with tar. The condition of these pipes is usually directly related to their age. Older ones are subject to damage through decay and root movement, whereas the more modern ABS ones are virtually impervious to damage, although some rare batches have been alleged to be defective. However, inasmuch as significant portions of drainpipes are concealed, I can only infer their condition by observing the draw at drains. Nonetheless, blockages will occur in the life of any system, but blockages in drainpipes, and particularly in main drainpipes, which I recommend having video-scanned. This could also confirm that the house is connected to the public sewer system, which is important because all private systems must be evaluated by specialists.
Marcel
Old 11/1/08, 7:37 PM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
It's been my experience that hydro-static testing of sanitary sewer lines is more reliable than video scans. HS testing can pick up on leaks that you cannot see with video. If I had to choose between the two I'd go with HS. Many companies that do this type of work will use both methods however.
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 11/1/08, 7:45 PM
John, a hydro-static test is usually done on new construction before it gets tied in to the service sewer main or manhole.
Not all sewer laterals are accessible via a manhole.
If private, the sewer main has to be accessible on both ends so one can install a balloon ball on one end and have a ten foot head pressure riser or introduce 5 lbs. of air pressure.
So, I would imagine that these scenarios are hard to come by in existing conditions, and a video scan would most likely be prudent at that point.
JMHO
Marcel
Old 11/1/08, 7:58 PM
Marcel:
This one works, if only because I recognize it as being close to one that I wrote as part of the InspectVue Residential narrative library many years ago. Of course, I'm no longer associated with InspectVue, or PVS.
John:
Thank you for your informative post.
Best wishes to both of you.
Old 11/1/08, 8:04 PM
Marcel:
I recognize the narrative as one that I wrote as part of the InspectVue Residential narrative library many years ago. Of course, I'm not longer associated with InspectVue, or PVS. Regardless, I believe that all narratives, regardless of where they originate, should be reviewed and edited to suit the user's needs.
John:
Keith, I'll be darn if I remember where I got it, but is it adequate?
Part of my Inspection template anyways. ha. ha.
Marcel
Old 11/1/08, 8:20 PM
Marcel:
Yes, of course.
It comes down an individual decision as to what works best. I never used to recommend a sewer scan, but I recommend them almost exclusively. Why? I do business in an extremely litigious state, have been the victim of frivolous lawsuits, and am no longer naive enough to think that truth and justice will prevail. Consequently, I shoot first and ask questions later.
Old 11/1/08, 8:22 PM
JMHO
Marcel
Might be a regional thing. Most homes around here have a cleanout that's accessible outside, that's where they put the balloon. Many of the older homes do not however.
John Onofrey
Old 11/1/08, 8:24 PM
Marcel:
Yes, of course.
Thanks Keith, If I used the narrative and it came from you, I made a good choice.
Thanks
Marcel
Old 11/1/08, 8:28 PM
Regional, ah yes, I forgot you were in Texas. ha. ha.
Our pipes are eight feet down at the house usually, minimum of five feet.
No cleanouts outside. One inside and hope the discharge is in a manhole.
Mine is not. Field connected wye in the street. 45 years old and knock on wood nothing happens. Cast iron.
Marcel
Step crack leading to further cracks gmendes Structural Inspections 4 6/21/07 11:40 AM
slab no cracks: Brick veneer cracks gkoehl Structural Inspections 1 4/17/07 5:52 PM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
