The house was built in 1948.
Home previously had a septic. Gas heat. There was a sealed area at the floor and also a device on what appeared to be a floor drain. Any ideas of what lies below the sealed area. It was hollow when walked on? Any ideas what the attachment is to the floor drain? My thoughts are: Bomb shelter Old drain crock But I really dont know and why I am posting. |
Was there a sump?
I have seen these where owners had problems with backup. They may have simply wanted to block the drain. |
No sump.
They have had the exterior drainage updated in the last 3-7 years. How would you call out these areas? I advised inquiring with current owner on history and application. |
Hmmmmmmmmmm............
OHIO.........., Cistern? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
That is a possability.
I wanted to open it up!! |
the object in the Drain appears to be an expandable drain plug David...I could only guess to keep out sewer gas but more likely to stop back up ...not a good sign i think....I can't tell about the covered area....anything in sellers disclosure????
I agree with Robert. Looks like an old sump pit.
Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
The covered hole in the floor is where the original coal furnace used to be; a newer or first concrete floor was poured around it. It has since been replaced with a gas furnace (in back ground) the hole in floor was never properly cemented shut, just covered up! The "Plumbers Plug" is used to pressure test new drain systems and also used to prevent frequent sewer back-up's, while eliminating your basement drainage system in case of a plumbing bust!
It's where the hide the bodies of buyer's inspectors that they don't like!
Run! Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
| AC duct not sealed | Lisa Bloemer | Inspecting HVAC Systems | 18 | 9/12/08 11:00 AM |
| Gas Sealed Fireplace Hearth | bglickman | Inspecting HVAC Systems | 4 | 1/18/08 12:44 PM |
| sealed foundations | gordonmoore | Structural Inspections | 2 | 9/24/06 4:57 PM |
