OK...have you guys ever seen the shower stopper with the upper opening so you can actually fill the shower with water and leave it running without fear of it overflowing?
I had one and it never seemed to seal properly and always had to store it in a container. So I got to thinking and went to Home Depot and this is a little tool that can come in handy to check shower pans for leaks. You can make this for a whopping...about $7 and in about 10 minutes plus silicone dry time. This was just an idea, please feel free to ctirique and upgrade. Step uno.... ![]() Tools are a pen, scissors, Silicone caulk, a rubber flat drain stopper and 1 1/2" plastic flanged strainer tailpiece 6" long. Mark the outside of the pipe with a pen (not the flanged side the thinner side). Cut it out with scissors making sure its as close as possible. To tight and it binds in the center and too big and it will leak. Push the pipe through leaving the flanged part under the rubber stopper. Put silicone around the seam, cut the pipe to whatever height...I went with about 2.5". Let the silicone dry...and BOOM.................DONE. I tried it out and it works awesome. Just wanted to share in case someone else needed this. ![]()
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Great deal Russell , Psst we will not let Sean know OK.
Seems it would be easier just to buy a tiny plunger and take off the handle.
The smallest one I found sits about 4 inches off the ground. I wanted something a bit more shallow. Good idea though.
LOL.......good point. I just worried about the flow rate to ensure it never overflowed. These are great ideas.
You can also use a razor knife.
These work fine too. A little more $$$.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
I stopped into a thrift store and picked up a container that is just 1/2 inch larger diameter, and a 1/4 inch taller, for about $0.10, and cut a piece of foam for the stopper to fit into so to avoid any curled edges from sitting between uses. I carry a couple of pyramid fishing weights to weigh down the edges if it doesn't seal properly to the shower. Simple and has lasted for a couple of years so far. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Nope... I've been going to PE for years, and never a problem with their website, or products, or service.
| No caulking at shower wall to pan seam? | hmiller | Interior Inspections | 11 | 2/9/09 7:40 PM |
| Classes/ Education for Mold | bwieczorek | Miscellaneous Discussion for Inspectors | 6 | 9/10/06 2:01 AM |
| Arizona, one day mold cert | dbucknavich | General Inspection Discussion | 4 | 6/26/06 9:32 PM |
