Old 11/18/10, 11:44 AM
William J. Decker's Avatar
Default Silly Builders - Funny conctruction defect pictures
Here are a few. Post your own and share.
Older building with through the wall A/C units and a new building going up, next door. What is a builder to do? Easement issue? Are the compressors crossing the property line? You would think that the Architect and/or Surveyor whould have seen this and, maybe, changed the building width by a few inches.
Answer: "Modify" the exterior block (8" split faced concrete).
Plus, no flashing above the balcony ledger. Hey kids, It's efflorescence time!
silly-builders-funny-conctruction-defect-pictures-dscf8467.jpg   silly-builders-funny-conctruction-defect-pictures-dscf8468.jpg   silly-builders-funny-conctruction-defect-pictures-dscf8469.jpg
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/18/10, 11:52 AM
Default Re: Silly Builders - Funny conctruction defect pictures
Here's another one. Newer CMU building. Lower level windows with no flashing or weep wicks, in fact the masons grouted the lintel space.
Look at the interior lintel. This building was about 2 years old. Single wythe CMU wall.
silly-builders-funny-conctruction-defect-pictures-dscf8605.jpg   silly-builders-funny-conctruction-defect-pictures-dscf8609.jpg   silly-builders-funny-conctruction-defect-pictures-dscf8611.jpg   silly-builders-funny-conctruction-defect-pictures-dscf8614.jpg
Will Decker, CMI
Old 11/18/10, 11:57 AM
Silly A/C compressor placement. Also note the efflorescence and try to determine its source of water intrusion.
The 2nd and third picture has the compressor installed on the parapet wall, with through bolting. Water leaks inside and below. (Hat tip to Jeff Merrit for these two pictures).
silly-builders-funny-conctruction-defect-pictures-p5250055.jpg   silly-builders-funny-conctruction-defect-pictures-ac_shelf_merritt.jpg   silly-builders-funny-conctruction-defect-pictures-ac_shelf_bolt_merritt.jpg
Will Decker, CMI
Old 11/18/10, 12:05 PM
Can you say "corbelling"? Mason rebuilt parapet wall of an older building and didn't seem to like that wall angle. Is this wrong?
Of course, at these this guy did a rebuild. Most just parge over the damage.
silly-builders-funny-conctruction-defect-pictures-p8240002.jpg   silly-builders-funny-conctruction-defect-pictures-p8240001.jpg   silly-builders-funny-conctruction-defect-pictures-parapet-parge.jpg
Will Decker, CMI
Old 11/18/10, 1:12 PM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
Here is a minor one
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 11/18/10, 4:57 PM
David C. Macy's Avatar
This seems like a good place to post this, no where near the concerns of Wills, but made me laugh. Just a simple 50 cent cover replacement.
I like the picture of the Pigeon!!
John, very convinient, shut off the switch, fan the sametime as lifting the towel.
Old 11/18/10, 5:09 PM
Michael J. Fox Michael J. Fox is offline
Silly home owners ?????????????
Old 11/18/10, 5:43 PM
Originally Posted by jshishilla View Post
Here is a minor one
That is a good one John, but you have to think outside the box like the Architect.
When you lift the towels off the bar, everything comes on, and when you drop the towel back on the bar, everything gets shut off.
I think David caught on too!
Old 11/18/10, 6:56 PM
And it helps to make sure that they use the bathroom fan.
Will Decker, CMI
Old 11/18/10, 7:13 PM
Will, still having fun with your split faced and split rib block buildings I see.
Back in 1975, I was a masonry foreman for the Company now, and that is all that was used for schools, which is what we were building mostly back then.
Talk about sh$t block. Without a block water repellent sealant, they are nothing but one big water spong.
Most of Maine stopped using it and the ones that do are coating it with waterproofing elastermeric coating that I have used in the past, but would have to call someone to find out the product name. All I know is that with that coating, it is proving alright.
Old 11/18/10, 7:20 PM
Tom Leahy Tom Leahy is offline
Will, seeing your glass block window reminded me of these.
silly-builders-funny-conctruction-defect-pictures-darryl-carter-104.jpg   silly-builders-funny-conctruction-defect-pictures-darryl-carter-147.jpg   silly-builders-funny-conctruction-defect-pictures-darryl-carter-146.jpg   silly-builders-funny-conctruction-defect-pictures-darryl-carter-148.jpg
Fort Worth Home Inspector
Dallas Home Inspector
Old 11/18/10, 7:30 PM
Tom, some builders just don't have a clue on water proofing and flashing. Do they?
Old 11/18/10, 7:32 PM
As to the elastomeric paint, we found that out. All the Public Storage facilities do that.
Did you see my latest article? See Here:
http://deckerhomeservices.com/Split_...ock_update.htm
Poor owner, bought the 20 year old single family three months before this. Is it common to grout the trusses into the block pockets like this? The poor guy is now having the entire top floor gutted, including the roof trusses.
BTW: We are starting to see structural collapses of the roof trusses. Wait until the snow load starts.
Glad I found this for the guy before he had a collapse, but sad that he has to pay for all this. Kinda like telling someone they have cancer.
What are your thoughts?
Will Decker, CMI
Old 11/18/10, 7:49 PM
Wow! Will, that is incredible. Never seen roof trusses installed like that before and what the concequences were, but now I see why it was never done that way.
Hard to believe that was all from water intrusion through the block, had to be leaking from somewhere to cause that extent of damage.
That is crap!
I inspect mostly newer stuff and no snow loads.
I am glad we live an Florida
John Shishilla
321-327-2950
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Requesting Pictures for Best Defect Award mcyr Interior Inspections 25 8/22/10 8:57 AM
-WANTED-Best Defect Plumbing Pictures lkage Plumbing Inspections 23 5/25/10 1:12 PM
When Home Builders Hit the Skids jburkeson1 Miscellaneous Discussion for Inspectors 0 11/14/07 3:21 PM
