kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I took the temp from the attic access, put it in hold mode and snapped a pic. There was one ridge vent and the blown-in insulation was blocking all of the soffit vents. Outisde temp was only about 70-75.
Recommend having a contractor remedy the situation because of improper airflow.
Yup. That's what I wrote.
According to this study and several others, "average" attic temp is 40 degrees F higher than the ambient temp. Variances to that would come at different times of the day, etc. I don't see 144 degrees as a defect. The blocked soffit vents, regardless of temperature, would be a defect. The darker the shingles, the hotter the attic. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 6/28/08 at 2:44 PM.. |
I only noted the blockage of the soffit vents and the apparent lack of ridge vents in the inspection....and of course advised further investigation by a qualified contractor. |
Jeff Orcas is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kevin,
the bigger problem in the Pacific NW isn't the high temp, its the mold that will grow on the backside of the roof in the cooler months. Warm moist air from the home will condense of the roofing and you will see dark spots. I tell my clients you can't have too much ventilation in these parts, Jeff |
Soffit vents being covered is a norm in my area. I find attic ventilation issues in 90% of the homes I inspect.
That gave me no choice but to design a web page on Attic Ventilation. It's simply amazing to see so many re-roofs and newly constructed homes that have ventilation issues. |
Stopping the moisture transport upwards (doing a good job and not lip service) usually reduces condensation enough so that additional venting is not needed!! |
My feeling is that if you are not seeing the attic at the worst time of the year (up north: coldest days in January/February), in most cases, it will be hard to truly make an accurate determination if there is a ventilation issue. I have a check box on my report that tells my clients to check the attic during this period. |
Brian,
I wish there were more coming on board with the conditioned method Maybe by the end of my career I'll see more than 1-2 a year Insulation/ventilation ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
dplummer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just out of curiosity, what was the indoor temp?
Doug |
By coincidence, I have been referring people to that article for 5-6 years now for the very last graphic of how to deal with kneewalls and outer attics in a truly energy efficient and cost effective manner. We were doing that in our insulation company about 1983-84. |
Here's a roof surface that I inspected which was only 9 years old. Not a single vent was installed in the entire roof surface. ![]() The Seller ended up calling me and yelling at me for telling my Buyers that the roof shingles needed to be replaced now. She told me that she had those shingles installed nine years ago. I told her to get a roofer in to evaluate her shingles, and if her roofer says that the shingles are fine, I'll buy the new shingles for my Buyers. She never called back. Hmmmm..I wonder why? |
David,
Not fair those look like they were a 5 year shingle to start out with. They almost got twice the life! Quote:
I'm sure you've seen this one that I now use Energy efficiency and insulation instructions for attics: http://www.southface.org/web/resources&services/publications/factsheets/9atticaccess.pdf What's your thought on Owens Pink-cap? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/29/08 at 5:11 PM.. |
| Existing home sales rose slightly in February as prices drop. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 3/29/08 11:53 PM |
| Slightly unusual water heater location | kweiss | Plumbing Inspections | 8 | 12/5/07 9:22 PM |
| Slightly elevated CO reading that went down -- explanation? | fbartlo | Inspecting HVAC Systems | 8 | 9/23/06 11:10 AM |
