A client calls me up telling me his general contractor is renovating his house and is doing a very sloppy job. The client is fighting with the contractor because he believes the electrical is not up to code, The plumbing is not up to code, the craftsmanship is not up to par and he want to hire me to inspect the work so he can take it to his lawyer and file for complaint.
The moment he said that, a red flag went up telling me not to take this job. I have not called him back yet. I fear because I would be the last guy in, my liability would be at a higher risk and perhaps open the door to be sued. I am thinking he should just call up a licensed electrician to certify the job for him. The rest of the work he should just take some pictures and document it for his lawyer. What are your comments and recommendations. Steve Steve Blayney Certified Home Inspector Certified Energy Advisor NACHI Property Systems Inspection 416 886-2PSI (774) sblayney@p-S-i.ca www.Nachi.org Remember, no home is perfect! |
If the hair on the back of your neck says do not do it then listen close .
I expect this is how you feel . I agree say, Gee I think this could be complicated I feel you could be better of to get an electrician and if needed A plumber so you can be sure you are properly protected if some one is trying to scam you. You have told the person they need to get an expert . All the best Please keep us all posted as this is how we learn . ... Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I'd have no problem performing the inspection. I'd show up and simply note what I see. I'd also inform the client that the inspection will not be a code inspection. It's simply an inspection of issues observed in readily accessible areas of the home.
It's not that hard to pick up on shoddy workmanship and report it. If he uses my report for court purposes, so be it. I'd have no problem standing in front of the judge and stating the facts. |
Hi. Steve;
I was in a litigation case a few years ago, doing an inspection for the Building Contractors Lawyer. Ironically, the Homeowner was suing the Builder for non-performance and sub-standard work. The homeowner had hired his own Electrician and foundation Contractor and when I got done the inspection, the problem was not with the builder, but with the sub-contractors that were hired directly by the owner. It went to court, I did not have to defend my report, but did nullify the report from the homeowners inspectors and the homeowner lost. Of course the contractor lost also, because his defense was $12,000 and I got paid $1,200 for my research and inspection time. I would agree with David here and I would also inspect, observe and note what you see, that is usually hard for someone to argue what you saw. Marcel </IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Just do your normal report, your liability is no different, There are plenty of clients that are planing on going down this path, they just don't tell you up front.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I agree with Cookie. If that little voice inside your head is telling you something, you should listen. Everyone is different, with different levels of experience. Not all have the confidence to take on variations from standard reporting. Just because someone like Cookie might choose to take this on - it doesn't necessarily mean that you should.
Good luck whatever you decide. John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree, if this job has had permits pulled then they need to call the building department of their city to arrange for the inspectors to come in and check each stage before proceeding, the inspectors will rarely show up on their own. My belief is that their are no permits for this job and that could be another can of worms altogether. WE ARE NOT CODE INSPECTORS.
dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
In Ontario, (especially Mississauga) a permit is required for any major renovation if you are adding any square footage to a house. If you are just changing items in an existing area, rarely do you need a permit. Unless it is major structurall changes. Find out if he or his contractor has a permit. If he is having an electrician changing electrical items, this does need a permit and inspections by ESA. Where is that permit? Has it been inspected? ( I looked at a new house Friday, the owner told everyone he has the final Inspection from ESA. I found one GFI receptacle that runs through another. Two dead GFI receptacles, one receptacle wired wrong, three wires resting on heat ducts, and finally only half the panel labelled. Code requires all of these to be addressed. He is calling ESA Monday. I even gave him the code reference to label the panel and told him as the inspectors are in the house a few minutes they may miss items. ) Plumbing is something a little different, there are certain codes that need to be met but some are hard to argue. Do pipes have the right amount of flow? Are they supported correctly? Just because there is glue all over the place, or pipes are not straight, may not mean it is "not up to code". Does it look professional? is an opinion many times. The same with general craftmanship. Your opinion is different from someone elses. If you inspect a house, you are looking for defects, not poor workmanship. Such as a loose handrail, or incorrect sizes of openings, on a set of stairs. However these would also be inspected and addressed by the cities building department. You would mention that, but the fact it is just half sanded and looks cheap would not be your report item. A poor drywall taping job is not a report item, unless it involves areas such as a garage where it needs to be sealed. Your report would mention that doors do not open and close properly and should be adjusted to work as expected, but you would not state things as, "the trim looks like a kindergarten kid did the work". It could come down to,,,, Are you prepared to back your statements up in court? Are you prepared to spend that time in court? If you do the inspection, remember to point out that these are your recommendations only. |
I would agree to do a home inspection and point out the problems I see with the workmanship and quality. I would also inform the client that HIs inspect to a higher standard that local code inspectors.
If he just wants a code inspection, I would ask him to call the local building dept. and have them do it. They should do it for free (paid for by taxes). Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
This type of inspection can be done, however you need to know you local building codes, you should have a good general knowledge of standard building practice for remodeling. you will need to interview the contractors, you are only getting one side of the story, I do 3-4 of this type per year last one I charged $4,200.00. went to job site daily to check on work and advise contractors of any issues.
Can be good money just cross your T's and dot the I's |
John Onofrey hit the nail on the head. It does not matter what I would do,
but what you feel you are competent with. Are you ready to engage a contractor in debate and possible debate with his lawyers in court. If your not sure, that is no shame. We all had to learn. Walk the other way. As the others have said, just report what you see, if you decide to go with it. I would add this about various items that have gone through repairs or are not visible. This means everything you can think of. The following is just an example. Note everything you cannot see such as flashing covered on roof by the siding touching shingles, inside the chimney it self, under insulation in the attic, inside walls, unseen electrical, unseen plumbing, underground, foundation covered with carpet, etc.... Also note that you were not present for repairs of sheetrock. If sheetrock has had previous moisture damage this may be conducive to mold, decay and wood destroying insects that is not always visible. Note any comments that the client makes in the report about items they saw before things were covered up. Tell the client that they should ask for all historical documentation of the work being done, such as previous inspection, blue prints, permits, approved specs...etc... and that they should seek Professional advise in order to understand these documents. Note poor workmanship that looks very obvious. You need to be nit picky in order to protect yourself. For every section that needs repairs, be sure to state that you recommend further evaluation and repairs, as needed by a qualified Professional (fill in the blank). A good moisture meter helps a lot. A thermal imaging camera helps even more. But, do what you can, with what you got. If you go to court, then look up the price for your average expert witness-tradesman in your area ($100-$200 per hour) and charge a few hundred dollars minimum. They will pay. Document everything with photos and try to make very good friend with your client. People don't enjoy suing someone that the have a personal relationship with (most of the time Good luck... John McKenna, CMI (TREC #4565)
| Limited Liability | rcooke | Canadian Inspectors | 6 | 6/5/06 2:08 PM |
| Case law on Home Inspections | rwand1 | Canadian Inspectors | 17 | 4/5/06 10:08 PM |
| Limit of Liability Clause | rwand1 | Canadian Inspectors | 6 | 3/6/06 6:30 PM |
