Old 10/30/09, 4:33 PM
Kenneth Greene's Avatar
Kenneth Greene Kenneth Greene is offline
Default Soil Testing
Hi Guys,
I was speaking with a couple young agents this am (ya know, hand shakes, card tansfer, basic small talk) and one of them asked me about soil testing.
Ok what is it, why would we offer it, and why were they asking about it?
Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America)
Old 10/30/09, 4:43 PM
James E. Braun, CMI's Avatar
Default Re: Soil Testing
You need to be a soil scientist to test soil. Soil test needs to be performed for most residential sewer systems and large commercial buildings in Missouri.
Old 10/30/09, 4:50 PM
David A. Selman David A. Selman is offline
Kenneth,
I dont know why the agents where discussing soil testing. I believe that you must be a soil engineer to test soil.
Here in Texas, soil tests are performed at home building sites to determine how the foundation will be build. This is done by the builders engineers.
In Texas, it is also sometimes used to determine the type of septic systems that can be used at a given location.
Regards,
David Selman
Selman Home Inspections
Old 10/30/09, 5:05 PM
Mark S. Tyson Mark S. Tyson is offline
Soil sampling is done prior to the start of a construction project. generally done by a geological engineering firm and most commonly using a split spoon sampler to determine three things (1) to obtain samples at various depths below the surface for the purpose of laboratory evaluation, (2) to determine the variation of the soil profile that exists on the site, (3) to determine the depth that free water is encoutered (water table). this testing is used to determine the suitability for construction and too aid the designer engineer with information to determine soil bearing values in relation to footing design. If your state has a land grant university you can probably obtain (free of charge) a soil survey for your state and will be available from the county agricultural extension office. if available it makes a great additon to your construction library. The agents were trying to blow smoke up your behind
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 10/30/09, 5:44 PM
Kenneth,
Regards,
David Selman
Old 10/30/09, 7:58 PM
Thomas G. Valosin Thomas G. Valosin is offline
Ken,
Have had several instances when Clients have requested a soil sample be obtained and sent to lab for analysis. (all prior responses are good examples) In my specific cases, the agents client had concerns regarding prior use of property. In one case, they wanted to do organic farming and were concerned selling farmer had "poisoned the soil with chemical fertilizers". In another, buyer knew seller did custom auto-body and auto-building work. They had concerns regarding various hydrocarbons that "might" be where they wanted to raise sheep. In still another, there were concerns regarding potential pollutants from a small engine shop.
I see by your post you are in Albany. Why don't you come on out to our NY Capital Region Chapter of InterNACHI meetings on the second Wednesday of each month at Doratos at 155 & 20? www.ny.nachi.org/newyorkcapitalregion/events
Give me a landline 518 827 4852
Tom Valosin, President
Old 10/30/09, 10:31 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
There are several different reasons for soil testing. The one that everyone keeps talking about is for soil compression testing typically done by an engineer. There are other reasons for soil sampling such as being part of an environmental impact study. You cna look for lead based paint in soil from around the perimeter of the house. You can look for PCB's in soil that would effect well water. You can look for pesticides in the soil that would also effect well water. The list goes on and on. Could be any number of reasons why someone would be talking about soil testing for a real estate transaction.
Old 10/31/09, 5:19 AM
Originally Posted by tvalosin View Post
Ken,
Tom thanks for the info and yes i am planning on trying to make some of the local chapter meetings.
Old 10/31/09, 9:14 AM
ldapkus ldapkus is offline
A garden planted next to a building with peeling/deteriorated lead paint can be a problem. Lead leaches into the soil and in turn into your veggies.
Old 10/31/09, 9:29 AM
Wayne B. Wilson's Avatar
your are worried about lead? in your veggies, How about
http://www.nrdc.org/water/pollution/nspills.asp
http://truefoodnow.org/campaigns/sewage-sludge/
Kinda of a new twist on just eat sh..t saying lol
Old 10/31/09, 10:16 AM
No I'm not worried at all. My garden does just fine.
Old 10/31/09, 10:38 AM
Me too i don't worry about it, After seeing some of the restaurants kitchens , Nothing can harm us lol
Old 10/31/09, 11:10 AM
Reminds me of the old saying, "That will put a little lead in your pencil"
soil testing (posted by susan thomas) AskNACHI.org AskNACHI.org Inspection Questions Forum 3 6/30/08 8:58 AM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
A sinking Home rcooke Miscellaneous Discussion for Inspectors 0 8/12/07 7:28 AM
Soil Testing Mike Jewett Ancillary Inspection Services & Additional Topics 2 7/20/07 7:43 AM
