Old 1/4/06, 9:13 PM
phinsperger's Avatar
Thumbs up Streets & Trips with GPS
I recently picked up Microsoft's Streets & Trips 2006 with GPS locator. What a cool product. The GPS tracks in real time my location and the Streets and Trips software plans out the route similar to mapquest but the driving guide tells me with the audio voice when and which way to turn with very good accuarcy. Gotta love it.
Old 1/4/06, 10:05 PM
Mark H. Roe's Avatar
Mark H. Roe Mark H. Roe is offline
Thumbs up Re: Streets & Trips with GPS
Paul,
These GPS toys are so neat I have a Garmin Ique 3600. Best thing next to Margareta's. I had the Delorme Street atlas for the longest time. It worked great to. But I always had to mess with the laptop. But now I just grab and run. Works great also to get information at the inspection site.
Old 1/4/06, 11:11 PM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Streets & Trips with GPS
What are you guys paying for your ???
Heck if it makes sense I might order it from out by you, everything here is so damn expensive, whew !!!
Old 1/4/06, 11:43 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
I have an older MS 2004 version, and love it. In addition, I also have a Magellan 600 which is pretty neat too! Sounds like I need to upgrade my Streets and Trips. One thing - I have noticed though using in Canada - some street level maps are inaccurate.
I believe the cost for the MS Streets and Trips is in $150(Cdn) range full version.
Old 1/5/06, 4:50 AM
rmoore's Avatar
rmoore rmoore is offline
Please Note: rmoore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good timing on this...for me.
Tuesday, I went to Best Buy looking for MS streets. I really only wanted the software so I could "push-pin" a map for each home I've inspected. Anyway, ended pcking up the DeLorme Street Atlas with software and GPS for $99. I purchased a tablet PC when I started this job, but ended up not using it. Figured I could finally put it to some use (business and pleasure).
I just took my first trip with the GPS and tablet (to the grocery store). Kewl!
I still have a learning curve or two to go, and I doubt I will use it much for HI work, but I can see how it would be very useful on rambling road trip vacations.
Now, if I could just read the darn tablet in bright daylight....!
Old 1/5/06, 7:19 AM
If you have one with a voice feature you don't have to read it. Just listen as it tells you which way to go at every turn.
Old 1/5/06, 7:37 AM
Kevin P. Williams's Avatar
Kevin P. Williams Kevin P. Williams is offline
I use a Garmin 2160, it has the voice also
I can't belive how good it is and how
much time it saves
Old 1/5/06, 7:45 AM
David P. Valley's Avatar
I use TOM TOM
This GPS is the best out there.
No programming involved. Take it out of the box, attach the device to your windshield or dash and enter your destination and start driving. It's voice activated and has a 3-D view.
I've never had a problem with this. I've found so many short-cuts utilizing TOM TOM. The best.
Old 1/5/06, 9:49 AM
Jeffrey R. Pope's Avatar
I use a Garmin as well (forgot which model). I've become dependent on it and can't find my way home without it
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/5/06, 10:01 AM
Jay Schwartz's Avatar
Jay Schwartz Jay Schwartz is offline
Nothing beats streets and trips when you have mulitple destinations. It will optimize your route. Works well when hurricanes blow down all your street signs and landmarks (trees) that your so used to seeing.
After hurrincane Andrew, I visited some people I knew that were hit. CBS construction home and tile roof. The ONLY way to know you were at the house was the TOILET. All that was left was the slab and their master bedroom toilet.
MS Streets & Trips can be purchased between $99-129 depending on rebates.
I use an earbud when travelling. Never have to look at the screen. Threre is a small learning curve. One is not to panic when you enter a highway ramp and it says "Off Route". The GPS is accurate within 100 feet. The U.S. military controls this feature. As a pilot, the runways are within 100 feet as well. I guess the military figures if your within 100 feet and still can't find where your going, I guess you may need to give up your license!
Jay Schwartz
Coast To Coast Home Services, Inc
Your Florida Home Inspection Company TM
Corporate Office: 954-673-3479
Naples Office: 239-298-4396
1-877-79-Windstorm
www.CoastToCoastHomeServices.com
www.SaveOnWindStorm.com
South Florida Home Inspectors Association
Southeast Florida NACHI Chapter - VP
Old 1/5/06, 12:22 PM
David A. Andersen's Avatar
I won't leave home without it!
If you get stuck in a traffic jam you can just bailout at the nearest exit/turn. The program will take you around it and back on course.
If you follow the MLS directions to the property you'll never get there! Real estate agents don't know left from right and North from South!
The only problem I have around here, is that they have multiple streets with the same names, sometimes even the same address number if the county is different!
Anyway, a great way to doublecheck where you're going in the best way to get there.
For $99, it's paid for itself several years ago!
Old 1/5/06, 1:04 PM
jferry's Avatar
jferry jferry is offline
Actually, it's so the enemy can't put a JDAM down your chimney, like we can its. And if you can't find an airfield without GPS, you need to have your medical updated.
Joseph A. Ferry, Esquire
Two Penn Center Plaza
Suite 200
Philadelphia, PA 19102
215-854-6444 tel.
215-243-8202 fax
Old 1/5/06, 5:59 PM
Sounds like we hit a thread here.. Like I said before,I do not leave home with out it.. Set your adress,listen as it talks you to your location. Pull it out of its cradle,and head for the house. Do you need to know which way north is? guess what? with a GPS,you know that know. I like the Garmin I-Que 3600 handheld unit. It does so much more than just telling you were to go. I get enough of that from my wife. I am looking into the Tom Tom. But the price! You can go on ebay and find the I-Que 3600 with the auto mount kit for around $360.00 to your door.
Old 1/5/06, 6:26 PM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am considering the ms streets and trips, have been looking at it for a while. I was wondering how rural it went?
Old 1/5/06, 6:26 PM
Doug Edwards's Avatar
I recently acquired a Palm Zire 72 GPS package (new in the box) on Ebay. It is so accurate it still amazes me. This unit uses the TomTom software as well. It is all Bluetooth so it works without the standard wires. It comes with a full package of accessories so it does have a charge cable for both the GPS receiver and the handheld. I already had a Zire 72 so I ended up with a spare. It too has 3D or expanded map. Programs like a dream. Takes only a couple of seconds to program in a destination. These go for around $700 but I did not pay nearly that much. This setup "talks you down" as well. One nice feature it has is "night colors" for the screen. The colors change to black with neon blue lines and graphics. Pretty cool. No more fumbling with the Realtors maps that aren't accurate or streets are mislabeled.
GFCI receptacle trips... lkage Electrical Inspections 4 6/20/07 8:39 AM
