Om Monday I'm doing an inspection on a stucco house. Customer asked if I did a stucco inspection and I told him that was part of the whole house inspection. Any suggestions on what to look for when inspecting. Also what is a good way to tell stucco apart from EFIS. Thanks David Lee
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Thanks for advice
Stucco hurts if you rap your knuckles on it.
Ouch. EIFS is softer, kind of like Mr. Charmin. A knock on stucco (use a screwdriver handle) sounds solid. A knock on EIFS sounds holld. Fortunately, stucco is so cheap here that only commercial buildings resort to EIFS. NACHI 2005 U.S. Member of the Year
EIFS is generally installed on foam backing board (EPS or extruded) that is glued to a substrate. Check the bottom of the system. If you can feel finish texture on the bottom, or, if they do it there like they do it here, just plain old foam or mesh (BAD BAD BAD) then it's pretty likely that it's EIFS. It is typically softer, but sometimes a heavier mesh is used (Panzer is Dryvit's version) and it can get pretty hard.
Give 'em my number if it's EIFS. I'll come to Florence, if for no other reason than to chuckle at the ol' water tower. www.centralohiohomeinspections.com |
Stucco also quite often has cracks. The wood in behind can expand and contract in varying temperatures unlike the stucco which then will crack.
http://www.usinspect.com/EIFSVideo/EIFsMain.asp
Check this one... ...and in Cincinnati, there is Miberg Technologies. He was an expert witness in the Dryvit court cases. Call me, I'll get you in touch with him... MALL, Y'ALL "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
| Need to ID type of stucco | cdewitt | Exterior Inspections | 20 | 12/4/06 11:39 PM |
| Stucco course | badair | Inspection Education & Training | 2 | 11/21/06 6:51 PM |
| Wisconsin stucco problem | dnice | Exterior Inspections | 6 | 10/17/06 9:03 AM |
| Stucco and Building Wrap | eyerise | Exterior Inspections | 5 | 6/29/06 9:35 AM |
| Romex Wire Through Stucco Wall | Tab M. Wilcox | Electrical Inspections | 12 | 5/11/06 2:33 AM |
