Can anyone tell me what causes small rust spots on exterior stucco (covering a masonary wall)?
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Metal corner bead or metal lath.
Random spots througout in the middle of the field would indicate moisture intrusion behind the stucco causing the metal staples that secure the lathe to rust. Pictures would be extremely helpful to help diagnose your problem.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Maybe the nails were left in place after they poured the tie beam and filled the cells. Florida Licensed General Contractor Florida Licensed Home Inspector #299 Wind Mitigation Specialist Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Good catch Mike forgot about those.
Finally my years of experience as a stucco contractor may have paid off. In high school it was my after school job to prep the houses for stucco.
Knuckle buster LOL
Yeah and we used to grease the windows with old motor oil and gas. mixed in a bucket. we DIPPED A FIRRING STRIP WITH A RAG TIED ON IT AND COVERED ALL WINDOWS AND FRAMES. sorry bout the caps my finger slipped. Long before they invented Window Guard. It was nasty in the Florida heat.
Many times Rust Spots are associated with Metal Shaving from the Mixer, or Metal Shavings-Debris in the Sand from the Plant.
But Metal Shavings regardless of where they originated from are common in Cement Stucco finishes and can make a building look like hell. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Woops...forgot he said it was a masonry wall when I posted.
I see lathe on painted block homes. They use the lathe when they stucco after a home has been painted. Not that unusual down here. John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
Now that you have read all the reasons why---PASS it on to a stucco specialist for moisture analysis PASS the liability David Moriconi
M3 Real Estate Inspection, LLC 816.665.5346 www.m3inspect.com iNACHI Certified Residential Inspector NRSB Certified Radon Measurement Specialist Certified Mold Inspector |
| There are over 12 types of stucco and EIFS | bgromicko | Exterior Inspections | 0 | 12/19/09 7:04 PM |
| EIFS/Stucco | mmerino | Exterior Inspections | 16 | 8/6/09 7:41 AM |
| Stucco Issues | jfunderburk | Exterior Inspections | 19 | 3/7/09 8:15 AM |
| Internachi's stucco course, only a few spots left! | ppeters1 | Inspection Education & Training | 3 | 12/13/08 12:22 PM |
| Internachi's stucco course, only a few spots left! | ppeters1 | Miscellaneous Discussion for Inspectors | 0 | 12/4/08 1:29 PM |
