Old 5/18/10, 11:33 AM
Curtis Hildebrand Curtis Hildebrand is offline
Send a message via AIM to childebrand
Default Stucco in various geographical areas
My area has a lot of do-it-yourself builders. No one seems to understand the concept of weep holes in stucco or the need for drainage. What's been happening a lot is contractors put stucco on houses and run it down onto the foundation with no way for the water to drain out. The lower part of the stucco then cracks and breaks off due to water getting in behind the stucco and freezing in fall and spring. What I want to know is, what are some of the methods contractors use in various areas to keep this from happening?
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/18/10, 8:29 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is offline
Default Re: Stucco in various geographical areas
South Florida most builders go as low as they can go but we have very little freezing issues here.
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Old 5/18/10, 9:00 PM
Brian E. Kelly's Avatar
Stucco needs to stop 6" before grade and have a Weep Screed installed around the entire building at the base of the wall.
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
Old 5/26/10, 4:59 AM
Contractors go as low as possible here too, even below grade, but water tends to wick up into the stucco that way and get into the wall. The information you guys provided is very useful. It will help me defend my case because everyone around here thinks I'm crazy when I talk about how stucco is actually supposed to be applied even though the current methods aren't working.
Old 5/26/10, 10:29 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Here's some thoughts (for traditional stucco):
  • There has to be a break where the wall meets the foundation
  • There should be no exposed substrate or sill plates at the bottom of the walls.
  • The traditional stucco should lap the top of the foundation by at least 1 inch.
  • At grade this helps prevent wicking and termite infestation; traditional stucco must be kept 4 inches above grade.
  • At higher locations on a home (such as above low roofs) this helps prevent water intrusion.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
There are over 12 types of stucco and EIFS bgromicko Exterior Inspections 0 12/19/09 7:04 PM
EIFS/Stucco mmerino Exterior Inspections 16 8/6/09 7:41 AM
Stucco Issues jfunderburk Exterior Inspections 19 3/7/09 8:15 AM
