This stuff was all across the front porch next to the house, in the rear sliding door tracks, under the kitchen sink, in the garage and basically everywhere around this 25 yr slab house. Termite guy that was there did not know what it is. Nothing dropped out of the vinyl siding when tapped on above this porch.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Did you taste it?
It kind of resembles Vermiculite. Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
Exactly what I thought, although the 'pieces' seem smaller than usual. Was someone in the attic clearing it away from the soffit vents? Where the walls insulated with it? Don't expect you to have those answers, just a few thoughts.
25 yrs old, all fiberglass insulation.
Did you lift the 'glass' to see if it has a vermiculite 'base'? Very common around here for a home to have (original) 3 inches of vermiculite, and later to have 'glass' laid over it.
Just trying to help... Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
| 10 Commandments | wdecker | Miscellaneous Discussion for Inspectors | 40 | 1/16/10 6:07 PM |
| Green Stuff? on the underside of this crawl... | swaskewicz | Structural Inspections | 3 | 11/8/09 5:38 PM |
| My new case for my STUFF | bdoles2 | Thermal Imaging, Infrared Cameras & Energy Audits | 20 | 7/30/08 7:07 PM |
| Second hand mold stuff.... | tdietrich1 | Ancillary Inspection Services & Additional Topics | 2 | 3/6/08 10:14 AM |
