I have never seen this done and wanted comments. A 100 amp subpanel fed from a wire connected to the main lugs of a 200Amp Main Panel Box. The main box had no spaces for expansion so I assume that is why they used the main lug connection.
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Any pics? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Ditto
Here is a picture..thanks
Absolutely no good.
No way! Why on earth would someone want to loop 4/0 aluminum?
Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com http://www.thehomeinspectioninstitute.com |
jwarner is a non-member guest and is in no way affiliated with InterNACHI or its members.
Double tapping is double tapping and this is double tapping. Fire hazard due to the double tapping of the wires.
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
