Does anyone know where a good source of infomation about the type and or composition of swimming pool plaster and or where this information can be found?
Also, any good interior pool paint product names, or locations that it can be purchased? |
jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Relax Joe. I think that even Russell will agree that plaster is a different animal.
Um, I have a question about Gunite. *ducks*
I have a 35 year old concrete 8’ deep in ground pool at my house, and I use a paint called Waterborne. It has held up very well over the last year of service. Best of all, it can be applied over epoxy or other pool paints that are very thoroughly cleaned first. And I mean pressure cleaned with TSP and 2400 PSI at about 1 to 2” nozzle distance to the pool surface. You need to totally de-gloss the underlying paint and give the new coating a good etched surface to adhere too. After paint application the pool needs to sit open to the air for about 1 full week to completely dry. Remember that Waterborne is a water based paint, so it needs all of its cure time to cure properly for pool service.
There is a better coating called Sanitred, but it’s kind of expensive, and takes a lot of preparation with sandblasting and open flame dehydration of the concrete before application. But with Sanitred you can waterproof freaking wicker basket! This stuff is amazing! It will withstand all known and possible levels of negative hydrostatic pressure. This is the force of underground water that tries to make your empty pool float up out of the ground like a boat. Sanitred will allow you to repair a severely damaged pool surface, one that is written off by experts as a loss. Figure to spend $4000 to repair a typical family pool with Sanitred. The typical pool is a 16x30 kidney shaped pool with 8’ deep end. But $4000 is good as opposed to completely replacing the pool. |
Thank You Cortland,
I have a number of customers who ask questions about the pools and the maintenance, so helping them answer their questions, although not a requirement, is part of inspection process. Pete |
| Swimming Pool Inspection | akhan | General Inspection Discussion | 6 | 2/12/11 2:53 AM |
| indoor swimming pool | rcarley | Ancillary Inspection Services & Additional Topics | 7 | 1/10/07 11:13 PM |
| swimming pool light | whellner | Electrical Inspections | 23 | 8/5/06 4:02 PM |
