| View Poll Results: Telesteps vs Step Ladder for attics | |||
| Telesteps works best for attics |
31 | 64.58% |
| Step ladder works best for attics |
17 | 35.42% |
| Voters: 48. You may not vote on this poll | |||
I've always used a step ladder for attic hatches but I'm thinking of buying a Telesteps for that purpose. If you have used both, which one works best?
| Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America) |
Telesteps.
You don't always have room to open a step ladder inside a closet. You can use telesteps to open the hatch. If it's a high hatch, you have more hight available. It's smaller to haul through the house. Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Certified Level II Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Slight thread drift maybe but here is some info that some may find useful
http://www.kfoxtv.com/money/10365793/detail.html B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 |
I have a 22' fiberglass Little Giant, and as far as I'm concerned, this is one of the most stable ladders I've ever used, especially when only used as an A-Frame(not fully extended) I've also got an Extend N' Climb, that I use inside the house, attic scuttles, etc... both of which I use on inspections. At home, I have two aluminum extension ladders, a small 16footer, and a large and heavy Werner 28', that I installed that thing that wraps at the top to widen the stance? (Wing Span? http://www.littlegiantladder.com/lit...wing-span.html) I think the LG is more stable and safer to use as an A-frame. To each his own I guess... Steven Waskewicz Rest Assured Inspection Services, LLC. 12615 Halleluiah Trail Elbert, Colorado 80106 Office 719-510-7703 mobile all the time Fax 719-495-7166 Serving Colorado Springs, and surrounding areas. www.restassuredinspection.com s_waskewicz@msn.com NACHIiid=NACHI06032370 Last edited by swaskewicz; 7/28/09 at 10:26 PM.. |
I've become use to utilizing both ladders depending on the height. Closet scuttles get accessed very easily with my step ladder.
I like seeing the pull-down stairs already installed. |
I have use step ladder for attic hatches when I first started doing inspections but now use Telesteps and sometimes my Little Giant dependiing on the situation and won't leave home without them... I actually have two Telesteps just in case one fails! |
Telesteps are great ladders... I like their design. However I always double check the locking system on each extended rung
The Inspection Consultant Inc. www.gtahomeinspector.com info@theinspectionconsultant.com tel: 416-843-7080 |
After my telesteps broke I bought an extend and climb ladder, it seems stronger, it is definitely heavier.
"Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
How did it break? Did it fail? Or did it get damaged.
The plastic parts gave up after closing it hard a few too many times.
I use the Werner MT-17 telesteps no problem so far.
InterNACHI ID: NACHI08062309 South West Home Inspections LLC. Inspecting most of Riverside,San Bernardino & Orange Counties |
I can two multi-use ladders 21' and 13' They are heavy, but stable.
John Shishilla Residential Contractor Accredited Claims Adjuster (ACA) Serving all of Brevard including: Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Cape Canaveral, Indialantic and surrounding areas. Honor Construction www.honorconstruction.com www.honorinspections.com "Brevard's Premiere Inspection Company" 321-327-2950 |
Werner and Telesteps two different ladders. "Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
Are you sure it wasnt a case of Type IA body on a Type III ladder?
Stephen Stanczyk Washington State Licensed Home Inspector # 221 Structural Pest Inspectors License # 71043 Vice-President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Safe Haven Inspections Puyallup Home Inspectors - Olympia Home Inspectors Tacoma Home Inspectors - Bellevue Home Inspectors Pierce County -Thurston County - King County - Snohomish County |
No I am not SURE, what are you trying to say???? "Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
| Parapet Ladder | mthomas2 | Exterior | 8 | 6/3/09 10:16 PM |
| Ladder Safety Extensions | mcyr | Misc. Discussion | 3 | 4/6/09 11:10 AM |
| Telesteps 12.5ft Telescoping Ladder $94.00 | gbell | Misc. Discussion | 2 | 11/20/08 8:34 AM |
| Ladder Safety from ITA | badair | General Inspection Discussion | 4 | 8/9/06 7:59 PM |
| Ladder safety by Rick Bunzel | gbeaumont | Misc. Discussion | 9 | 3/24/06 6:24 PM |
