Ron Jeremy is a non-member guest and is in no way affiliated with InterNACHI or its members.
![]() Was told this install was not correct by gas company workers . have no specific things that were wrong just that it was wrong. is it the down turn after the trap before the flex pipe? |
rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ron,
I loved all your movies. |
Flex line can not go thru a steel cabinet. Its hard to see in the photo
I don't see the problem. But use the correct terminology: "appliance connector".
Sorry about terminology. appliance connector does not go through cabinet it connects right outside cabinet. Going to get rid of bend and hope it makes them happy.Has anyone came accross utility works that are just old fashioned and just dont like flexable piping instead of ridged?
Make sure the appliance connector is 36" or less also. I agree that getting rid of the 90 degree down bend by rotating it would probably be wise. Also, be sure the gas piping is supported properly. Personally, I'd be more concerned about whatever that is that was used on the W/H TPRV discharge piping. Make sure that's an approved material.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Hi Ron
The flex line has to be connectted to a tee. The elbow there is against code. 6.11.4 Where an appliance is connected to a flexible piping or tubing system connection to the appliance shall be outside the cabinet and into a tee fitting containing a drip pocket and rigid piping that extends to the appliance gas valve. Hope this helps. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ron , the drip leg needs to protect the gas valve and it is down stream in this picture. (sorry , I just saw this thread.) Put that shutoff on the tee! |
Sorry Bob but you are wrong on the placement of the valve. This is the correct positioning. In order to clean out the drip leg, it would have to be after the valve so the gas can be turned off to remove the cap.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Buzzzzzzzzzzz...wrong answer. |
You aren't protecting the shut off valve, it is either open or shut. You are protecting the burner/orifice of the unit. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I should have cheated and looked it up first. First time I ever heard of them not being rquired some where. You Californians are a bunch of freaks. |
Hi Will
It's based on the Canadian Standards Association code B149. Which is our National natural gas and propane code. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
| How to install a water filtration system? | dmacy | Plumbing Inspections | 22 | 6/30/08 9:16 AM |
| Free Books And Articles For Electrical | jtedesco1 | Electrical Inspections | 14 | 1/6/08 7:45 PM |
| Flex Gas Connector | Tab M. Wilcox | Plumbing Inspections | 4 | 3/16/06 5:01 PM |
