What is your opinion of this Black & Decker leak detector.
They are only 39.99 http://www.networkworld.com/supp/200...eckerleak.html Item was in a recent Handyman magazine article pertaining to energy savings. |
Looks like a laser thermometer to me...what makes it a leak detector?
maybe the fact that its your assertion that a wide difference in temps between close areas indicates a leak? Interesting...although I already have a laser thermometer, I never thought to use it in that way... |
Ah, I see said the blind man.
jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
All IR thermometers work that way, the laser is just a marker, it does not take the measurment. The IR detector does, move further back from your target and you will see the accuracy of the temp change as the detector span widens over the distance.
If I were to purchase this, it would be utilized as an infrared thermometer, not as a leak detector.
I use mine on a daily basis. |
Wish I had seen this before I spent $4,000 on my IR camera
Darren,
Thermography is the use of an infrared imaging and measurement camera to "see" and "measure" thermal energy emitted from an object. Your camera does both. The item discussed here only measures. Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
I comment was to be take as sarcastic
| Amprobe Microwave Leak Detector | rgant | Interior Inspections | 16 | 3/11/11 2:21 AM |
| Flir thermal imaging | vmitchinson | Canadian Inspectors | 0 | 10/8/08 5:31 PM |
| Thermal Imaging Next Steps | thauswirth | Thermal Imaging, Infrared Cameras & Energy Audits | 19 | 9/25/08 5:37 PM |
| Toilet leak (tank to bowl) detector dye tablets | kshepard | Plumbing Inspections | 9 | 9/9/07 1:34 AM |
