Old 11/11/11, 1:05 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Top 10 Recommendations
Hi everybody.
In order to cut a deal with ACE Hardware, Home Depot or Lowe's to provide $25 gift cards to every InterNACHI Inspector, they want some general understanding of the following:
What are your top 10 items that are most frequently recommended to repair, correct or replace?
For me, my top 10 items that I most frequently recommended to repair, correct or replace were:
  1. Plumbing problems (toilet, faucet, drain, drips)
  2. HVAC (service and cleaning recommendation)
  3. GFCI (broken, missing or miswired)
  4. Electrical (bad or improper wiring)
  5. Gutters (cleaning or repair needed)
  6. Window (damaged, cracked or inoperable)
  7. Exterior siding problems (paint, caulking, rot, trim)
  8. Roof (flashing, damaged covering)
  9. Insulation (missing, inadequate, improperly installed)
  10. Handrail (loose, missing, not safe)
What are your top 10?
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/11/11, 1:36 PM
Bob Elliott's Avatar
Default Re: Top 10 Recommendations
Totally different from what mine would be.
Most common write up is a toss up between lack of kitchen exhaust method or openings in a tub/shower area
Most common $$$ issue would be exterior wall cover step cracks,missing mortar,lack of flashing,etc.
You almost need this in two sections for serious issues observed and common minor issues that can cause a future serious issue.
No doubt location will be a big factor in the answers.
Old 11/11/11, 1:53 PM
Lack of smoke and CO detectors in their proper places is probably my #1.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 11/11/11, 1:57 PM
Christopher Currins's Avatar
What ever the defect may be I recommend repair/replacement to be done by a qualified professional, not by my client.
Christopher Currins
Certified, Licensed
Old 11/11/11, 1:59 PM
Jeffrey R. Jonas's Avatar
Or divide into... DIY and non-DIY.
Also, "Chicago" Urban is going to be a heck of a lot different than "Minnesota" Rural, or "Los Angeles" Suburban.
Old 11/11/11, 2:14 PM
1. Terracing, grading, gutters, downspouts, vegetation.
2. Roof.
3. Electrical.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 11/11/11, 2:26 PM
Charley L. Bottger's Avatar
You guys having a hard time counting to ten
1. Plumbing faucets/drain line leaks
2. Dishwasher drain line no high loop installed
3. Electrical GFCI's not tripping
4. Electrical double tapped breakers
5. Loose electrical connections main/and or sub panels excessive temp
6. A/C exterior condensers blocked with lint
7. Dryer vents improperly terminated and or joints having screws installed
8. Missing insulation on A/C supply air ducts in a non-conditioned space
9. Missing and or lack of insulation within the attic
10. A/C A-coil blocked with lint due to lack of return air filter changeout
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Daniel W. Levia, CMI Daniel W. Levia, CMI is offline
Caulking
downspouts
vegetation
flashing
plumbing
electrical
HVAC
roof
insulation
exhaust fans
Dan Levia, CMI
Past President, Alberta InterNACHI
In-Focus Home Inspections
403-350-9697
www.infocusinspections.com
info@infocusinspections.com
Old 11/11/11, 2:29 PM
Out of the three I listed, there are hundreds of items within. I figured three would be enough. You can also check the bottom of this page on my web site. This list has not changed in 8 years.
http://www.metrospeckc.com/Home_Inspections.php
Old 11/11/11, 3:43 PM
You must have some HVAC experience.
Christopher Currins
Certified, Licensed
Old 11/11/11, 3:55 PM
John Scaparo John Scaparo is offline
Here are two that most certain to be on maintance list, downspout extensions and furance air filters.
John Scaparo
Innovative Home Inspection, LLC
Canton, Michigan 48187
734.664.5853
john@InnovativeHomeInspection.com
Michigan Licensed Residential Builder
2101201845
InterNACHI MI #09041012, AHIT Member
Plymouth Michigan Home Inspector
Canton Michigan Home Inspector
"Helping To Secure Your Home Investment"
Looking for link exchange partners.
If interested send me your link.
Old 11/11/11, 4:10 PM
Not much but that listed is just common sense stuff
NACHI Member
State License # 130
Old 11/11/11, 4:14 PM
Are there any recommendations that always appear in your inspection report? As a default.
For example, Get the HVAC system serviced and further evaluated.
BEN GROMICKO
Old 11/11/11, 5:02 PM
Blower filters, garage door/opener maintenance, exterior caulking/paint, door knob adjustments/lubrication, gutter cleaning, faucet/water line monitoring.
Old 11/11/11, 6:05 PM
I have only one that appears in every report and it pertains to the topography of the landscape surrounding the foundation. I try not to insult client intelligence If the client is a mechanical engineer or a single mom determines what default goes into the report
NACHI Member
State License # 130
Recommendations for software tdunn General Inspection Discussion 9 8/10/07 6:02 PM
looking for PIM software recommendations jeubank Inspection Hardware, Software & Publications 3 1/2/07 4:23 PM
