Old 9/16/11, 12:07 PM
Nick Gromicko's Avatar
Default Try my online home inspection fee calculator.
You can set the base rates then input data for each inspection. Great if you have an office manager bidding your inspection jobs while you are out in the field.
http://www.nachi.org/fee-calculator.htm
Find a Home Inspector
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/16/11, 12:10 PM
Jeffrey R. Pope's Avatar
Default Re: Try my online home inspection fee calculator.
We can only hope that some will follow this as a general guide to pricing...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/16/11, 12:23 PM
You can adjust the Standard Rates box depending on your thinking. For example, in Los Angeles your Mileage Factor should be set higher (because of traffic) than if you are in Wyoming.
If you set up your Standard Rates box, your office manager can then correctly bid jobs for you.
Old 9/16/11, 1:44 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
One could only hope.......
Stephen Stanczyk
Old 9/16/11, 2:35 PM
For sure. I keyed an inspection I lost last week. This quote is $641 without termite. I quoted $525 with termite and radon, and lost it to another company at $349. Cheap is cheap. I told him good luck. Same with this formula.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 9/16/11, 2:58 PM
Christopher Currins's Avatar
Nick, send the calculator to all the real estate brokers on your bulk email list.
Christopher Currins
Certified, Licensed
Old 9/16/11, 3:15 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
NICE IDEA.
$429.25
Today's Inspection
How many miles will you have to drive (one way) to get to the property? 50 miles
How old is the home? years old
1950
How large is the home? square feet
1600 sq ft
About average
Age factor .015
Standard Rates
Please adjust these options to match your pricing structure.
Base Price: dollars
Mileage Factor: dollars per mile
Age Factor: dollars per year *
Size Factor: dollars per square foot
* Please note that the age factor will be adjusted by the size factor as well, because the size of a home becomes more of an issue the older a home is.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/16/11, 3:32 PM
You have to play with the Standard Rates box a bit to get it to where you want it. Also, the drop down box increases the price if your schedule is full (very busy or swamped).
Old 9/16/11, 3:44 PM
KEVIN WOOD's Avatar
Sweet I like that one even more. $551.20
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/16/11, 8:58 PM
Been playing with this thing for the past hour. Worse than Space Invaders (oops, now I've revealed my age).
Old 9/16/11, 10:01 PM
Tim Spargo's Avatar
Space Invaders
Exportable code to website or desktop or? The variables could *maybe* be prog'd to allow for snippet to be placed on desktop if a secretary or similar answers the phone OR ..?
Cool BTW
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 9/17/11, 9:00 PM
I moved it to my web site BUT would not work there
Old 9/17/11, 9:06 PM
Works nice here, but when I saved the link to my computer and tried it / She no work ????????????????????????????????
Old 9/17/11, 9:17 PM
Dale Duffy's Avatar
Comes out to about $25.00 less than I charge....works well Nick...!
Home Inspection Fee Calculator
$619.58
Old 9/18/11, 8:10 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Right on Jeff. Actually after playing with it a little, it is pretty much jiving with my normal pricing methods .
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Inspector listings by county rcarter Miscellaneous Discussion for Inspectors 8 8/22/09 10:40 AM
Liability question jcahill Legislation, Licensing & Legal Issues for Inspectors 30 8/24/08 4:10 PM
