Or maintain existing standards. I inspected a house built in 1935 that had a small concrete column that had shifted in the crawlspace. It as well as the others was not on a pier pad. I recommended that it be corrected to original standards, the owner said that he would bring it up to current standards and I told him that was his option.
Should I have recommended that it be brought up to current standards? If so where does that recommendation end? Crawl and attic venting? Elec. panel access? |
| Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America) |
Codes are not retroactive. . .
many are grandfathered.
dmcauley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is verbiage I put in for items that need correcting, "Recommend repair/replacement by a qualified contractor to the best standards prior to closing."
Hope this helps. |
For example, if the roof was framed in the tpyical manner but is sagging, you need to recommend bracing be added. Be sure to educate your client that these improvements rarely help the cosmetic problems with old houses but they will prevent further movements and damage. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Excellent advice, thank you. Fortunately the support system was good but for the one column but who knows with the next one. On a different subject why are flys called flys but fish aren't called swims?
InterNACHI SoP state:
An Inspection Report shall describe and identify, in written format, the inspected systems, structures, and components of the dwelling, and shall identify material defects observed. Inspection reports may contain recommendations regarding conditions reported or recommendations for correction, monitoring or further evaluation by professionals, but this is not required. All you have to do is identify the material defect. You do not have to prescribe the repair method or recommend a repair person. |
I think you'll do quite well here . . .
You can't do New Work to Old Standards. It must be done by current standards.
You should not be addressing old standards as an issue unless there is a significant deficiency associated with it. Then it must be repaired, to current standards. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
In NC we must also give the buyer a better understanding of the property conditions.
In SC we must report the condition of the property. If you take it upon yourself to decide what is important or not to the buyer you are simply not meeting the standards. I don't think NC has ever investigated an inspector that was found to be 100 percent in compliance. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| A Mission to Change the Standards - Let's Debate | krichardson | Miscellaneous Discussion for Inspectors | 74 | 12/19/07 8:29 PM |
| Texas Warranty Inspection Standards | badair | General Inspection Discussion | 5 | 9/30/06 5:12 PM |
