Old 3/3/09, 7:16 PM
Michael R. Dogoda Michael R. Dogoda is offline
Default VA inspections
Has anyone done any inspections for the VA? I have had realtors ask if I was VA certified? I have done plenty of inspections for active duty veterans and none of them have ever been kicked back? How do you get on the list, or is there such a thing ? or is it even necessary?
Thanks
Old 3/3/09, 8:32 PM
kpierce's Avatar
kpierce kpierce is offline
Please Note: kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: VA inspections
In WA, I don't know anything about a "list". I've done multiple inspections for clients with VA loans. The only difference I run into is that they always want the NPMA-33 for WDOs. However, we're required to be licensed for WDOs up here, not sure about FL requirements.
Old 3/9/09, 11:06 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Yes there is "A List".
Thanks
I have been a VA inspector for many years.
Contact your local VA administration and tell them that you want to conduct inspections for their office.
There are many forms to fill out, criminal background checks, Certifications & Criteria to be met and an extensive written test.
Good luck!
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 3/9/09, 9:21 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
Frank,
In your opinion is it worth the time & effort?
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 3/9/09, 9:28 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
I have been doing them for years, and have never had a problem, Based on where I'm at they to require the NPMA 33, I looked into going through the process but the time and effort was to great with little return. The buyers go through their local mortgage companies, so I just didn't think it was worth my time.
Frank have you found it to be a financial success?
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 3/10/09, 9:53 AM
Kevin and Troy,
In all the years that I have been a "Code Compliance V. A. Inspector" I have never had a problem getting paid and or getting paid on time.
Up here we get paid $150 per inspection to include each phase of any "draw inspection". Some new homes can have as many as eight inspections before completion. {NOTE: Banks pay up to $250.00}
I encourage you to "think outside of the box".
Once you are "NPMA certified" you can not only conduct "Bug Inspections" for the VA but.... you can also conduct "Pest/insect" inspections as an independent and Nationally Certified Insect / Pest inspector!
  • Up here on average pest inspections range from $175.00 to $250.00 You can do two or three per day!
  • The NPMA certification has to be renewed every three years.
I just completed a technically difficult two day course that had a high failure rate so if you are going to take course I strongly encourage you to study the manual that will be sent to you.
  • In my opinion it is well worth while!
The "local mortgage companies" have a list of VA Certified/approved inspectors and if you qualify and pass all of the tests and criminal background checks you too can be put on that list!
Some banks pay as much as $150 to $250 per draw inspection so yes I believe it is a "financial success".
  • Some of you receive phone calls from "middle eastern speaking people" requesting you to conduct $20-$30 "draw inspections".
These same people are receiving the $150-$250 from the banks who just can't seem to find qualified/certified inspectors!
Once the VA knows that you are a qualified and certified inspector you will permitted to fill out the application forms, the criminal background investigation forms and to take their written exam.
{My exam was 200 questions long.}
Once all of this is completed I strongly urge you to go to each and every bank in your area and speak to the person in charge of approving “Construction / Remodeling / Repair & Renovation Loans” and get on their “VA Approved List of inspectors for new construction and or Draw Inspections!
  • You could wind up doing ALL of the banks "New Construction loan inspections".!
There are "different types" of the VA inspectors. I am a "Code Compliance Inspector" and I specialize in “The Americans with Disabilities Act" {ADA} type inspections.
For this type of inspection you not only have to know all of the building codes but you also have to know the ADA/handicap requirements and codes.
I urge you become ICC Certified.
Good Luck!
Old 3/10/09, 10:02 AM
Thanks Frank,
Great info.
I am Certified through the Ohio Dept. of Agri for the bug inspections here. They use the NPMA-33 form. I include them with every home inspection.
Is the NPMA cert you mentioned a State or National cert?
Kevin M. Leonard
513-895-7700
937-283-5118
Old 3/10/09, 10:07 AM
Originally Posted by kleonard View Post
Thanks Frank,
Great info.
Hi Kevin,
I was told that it is a National Certification.
The presenter was Dr. George Rambo!
Old 3/10/09, 12:54 PM
Thanks Frank
Troy Farmer
PO Box 2144
Eagle, Idaho 83616
208-573-5300
Old 3/10/09, 1:11 PM
Thumbs up Re: VA inspections
Thanks Frank - I will be contacting my local VA office to check into this.
I appreciate all the info.
Kevin M. Leonard
513-895-7700
937-283-5118
Old 3/10/09, 1:46 PM
Just contacted my local VA office & they are getting back with me to talk with a gentleman in Cincinnati to get set up for testing.
The Lady I talked with told me she was acually involved with creating the test. I told her I had passed the NHIE & she said "well wait to you see our test - hahaha".
Wasn't quit sure how to take that but it did send a small shiver up my spine.
Many Thanks Frank!!
Kevin M. Leonard
513-895-7700
937-283-5118
Old 3/10/09, 4:25 PM
Kevin,
I just squirted Pepsi all over my desk!
Many Thanks Frank!!
I suggest that you and all others who want to conduct VA inspections review ALL of the material that you used for the NHIE and re-take the NACHI test at least 8 to 10 times.
I would also urge you to take ALL of the "Free" NACHI on line courses.
  • My test was 200 questions long and it was a "doozy"
  • You will need to know the building Codes.
  • I have EVERY Code book that the ICC publishes.
I also suggest that at a minimum you buy the ICC “Loose Leaf” version with {Turbo Tabs} of both the International Residential {IRC} & International Building Code {IBC} books {with commentaries}.
Once you are ICC Certified this will open a LOT of doors for you. You can conduct VA {Federal}, City & State Inspections all over the nation.
I highly recommend it!
Good Luck!
Old 3/10/09, 4:26 PM
Thanks Frank
Troy,
You are more than welcome. I hope that this information was of some use to you.
Good Luck!
Old 3/10/09, 5:05 PM
Sounds intense. I hope this is a lifetime cert.
For the Ohio Dept. of Agri I have to attend an 8 hour class every 3 years.
Sounds as though it may be worth it.
Kevin M. Leonard
513-895-7700
937-283-5118
Old 3/10/09, 5:48 PM
Intense? ....... You Bethca!
As long as you keep all of your "Outside" Certifications "current" and fulfill your yearly continuing education requirements you will be okay.
I say “Go for it”!
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 230 3/21/12 9:35 PM
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
