Old 8/6/11, 8:11 AM
Eric W. Augustin's Avatar
Eric W. Augustin Eric W. Augustin is offline
Default I want one!
No more bent gutters!
Eric W. Augustin
A1 Certified Home Inspections
If you can't explain it simply, you don't understand it well enough.
Albert Einstein
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/6/11, 8:58 AM
Michael Larson's Avatar
Default Re: I want one!
Originally Posted by eaugustin View Post
Now all you have to do is bring a shovel and some sod to repair th dents you make in the lawn.
Michael Larson
Hudson, WI
[/I]
Old 8/6/11, 9:25 AM
I'm an Inspector, not a Landscaper. Hell, I don't even repair my divits on the golf course.
Eric W. Augustin
Albert Einstein
Old 8/6/11, 9:26 AM
Oh you're the one.
Michael Larson
Hudson, WI
[/I]
Old 8/6/11, 9:35 AM
Barry Adair's Avatar
thnx Eric,
nice additional device for us that can figure out when/where to use
great for commercial-spections
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 8/6/11, 9:40 AM
Tim Spargo's Avatar
I thought ladders were designed to "lean" against a surface at the top of where they are resting against.
I can kinda imagine a ladder "snapping" right above that set of grips, as it resides well in the lower third.
Here's an idea to create some visual assurance, tie a rope to the top couple of rungs as the ladder is well extended in the air, then "tug" on the ladder a bit, pulling it forward, then measure the force needed to create failure...
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 8/6/11, 9:52 AM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
If you used that on an under rated lader it would be more fun than a carnival when it twist into a pretzel. High pucker factor.
Old 8/6/11, 10:03 AM
Tim Spargo's Avatar
VHPF
New term, Very High Pucker Factor
Tim Spargo
661-317-5770
Old 8/6/11, 10:19 AM
man are you tryin' to spoil all the fun
leaving little or nothing for the surviving family members and mfg to fight over in court
besides the fact this could be another one of those endless threads that has nothing to do with pol. or rel. and lead to further discussion ladder safety links and articles
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 8/6/11, 10:35 AM
Bob Elliott's Avatar
Ladders are not designed for that leverage so good luck to any using that thing.
Might be OK if backed into a pole for phone and cable guys in winter however.
Old 8/6/11, 10:50 AM
Harry D. Vandermeulen Harry D. Vandermeulen is offline
I saw a Verizon guy working on a line the other day and couldn't figure out what was holding his ladder up. Thanks for clearing up the mystery.
Old 8/6/11, 10:56 AM
Yes, the pucker factor is way up there...
Eric W. Augustin
Albert Einstein
Old 8/6/11, 1:26 PM
Jeffrey R. Jonas's Avatar
Did you also notice in the video, that in every instance shown, the worker NEVER climbed above the highest rung of the lower section of the ladder?
Old 8/6/11, 2:13 PM
Tim Spargo's Avatar
I think that's a realistic prediction. What do you suppose the actual number of links to ladders safety will be? I say 4 or less
Tim Spargo
661-317-5770
