Old 11/22/06, 7:53 AM
Carl Pennick's Avatar
Carl Pennick Carl Pennick is offline
Exclamation Warm Light Switch Cover
On an inspection I carried out on Monday, I noticed a wall mounted light switch cover become very warm after just a couple minutes.
So if you do not already do so, it may be a good idea when you turn on a light always put your hand on the cover plate.
www.wisemovehomeinspection.com
Carl Pennick
Lighthouse Point, FL
954-946 2737
407-928 8489
Florida Licensed Home Inspector #65
NACHI #04072098
ICC #5294144
Certified Master Inspector
Old 11/22/06, 7:57 AM
gbeaumont's Avatar
Default Re: Warm Light Switch Cover
Hi to all,
Good point Carl, but it is worth remembering that if he switch is also a dimmer, that these will always run much hotter than a standard switch due to the resistance generated by the variable rheostat which controls the light.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/22/06, 8:21 AM
Thanks Gerry,
Does that mean I get a green a square & NACHI will promote me from "unhelpful tosser", to just plain "tosser"
Carl Pennick
954-946 2737
407-928 8489
NACHI #04072098
ICC #5294144
Old 11/22/06, 8:28 AM
Roy D. Cooke, Sr's Avatar
Great tip but use the back of your two middle fingers ( More sensitive )an old Electricians trick to find hot breakers .
Roy Cooke
Old 11/22/06, 8:51 AM
Nice one Roy thanks
Carl Pennick
954-946 2737
407-928 8489
NACHI #04072098
ICC #5294144
Old 11/22/06, 9:16 AM
Keith Swift, PhD. Keith Swift, PhD. is offline
A warm cover could also indicate the presence of alluminum wire.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI
Old 11/22/06, 11:32 AM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't believe a proper load capacity and wired dimmer switch should operate much hotter than a normal toggle switch. I use a thermometer on the switches and refer to a sparky when temperature changes of more than 10 degrees are noted. Dozens of switches have been replaced and or rewired from my inspections with no complaints from the seller and or the sparkys called to further inspect/service.
Old 11/22/06, 11:52 AM
Bruce A. King's Avatar
The dimmers made in the last decade or longer are much warmer but not from the rheostat. The heat comes from the triac or thyristor that is used to drop the output voltage. A large heat sink is also present to help shed the heat.
Old 11/22/06, 10:51 PM
whandley's Avatar
Be aware that dimmer switches can only handle a specific amount of light load. You can typically purchase dimmers that are rated for 600 or up to 1,000 watts of lighting. Light bulbs are usually clearly marked as to their wattage. Determine the total wattage of the bulbs that are being controlled by any one dimmer. Purchase the correct size dimmer switch to suit your needs. But keep in mind that the metal heat sink plate on the front of many dimmers can be altered so that you can place multiple dimmer switches next to one another. If you break off the side tabs of the heat sink, as allowed in the instructions, you need to derate the capacity of the dimmer. If you snap off the tabs on both sides of the heat sink a 600 watt dimmer becomes a 400 watt dimmer.
"Tim Carter @ Ask a Builder"
Old 11/23/06, 9:34 AM
Russel Ray's Avatar
From my educational Interactive Report System:
Dimmer lights/light switches present. Dimmer light switches sometimes become warm to the touch. Condition is common, particularly with older switches but can also sometimes indicate other electrical problems, such as a dimmer switch installed by a homeowner on a light fixture that draws too much electricity. Determining whether or not a dimmer switch is properly matched to the lighting fixture being dimmed is beyond the scope of the home inspection. If the dimmer switch installation instructions are available, check the maximum wattage for the dimmer switch and then note the wattage for the light bulb that is installed. Make sure the light bulb wattage is not more than the maximum wattage for the dimmer switch. If it is, change to a lower-wattage light bulb. If you have any concerns, or if you notice flickering or brownouts at dimmed lighting fixtures (or any other lighting fixtures), consult with a licensed electrician.
Old 11/23/06, 10:49 AM
Doug Edwards's Avatar
Very often I have found dimmers for lights being used for ceiling fans and visa verse. It is important to verify this especially if it is already displaying unusual symptoms of a problem.
Old 11/23/06, 11:05 AM
bsumpter bsumpter is offline
It can also never hurt to mention that most compact florescent bulbs are not designed to operate under reduced voltage.
If you notice the bulb, or as often as not, the switch 'buzzing', check the fixtures for the CF bulbs.
Brian R. Sumpter
First Call Inspections
Proudly serving most Bay Area Counties
www.firstcallinspections.com
Light switch where entering a room. mgault Electrical Inspections 19 11/17/07 8:00 AM
Bathroom light switch question Jim White, #3 Electrical Inspections 2 10/16/07 3:21 PM
Need help.What type of light switch is this ? dnasser Electrical Inspections 3 10/7/07 2:41 PM
Light Bulbs- All Ya Wanna Know pabernathy Electrical Inspections 9 4/18/07 7:22 PM
How many forum members to change a light bulb? kshepard Miscellaneous Discussion for Inspectors 9 8/2/06 9:56 AM
