rborders is a non-member guest and is in no way affiliated with InterNACHI or its members.
On a new construction, there is a lot of water standing in the gravel of the rough-in of the shower drain. Is this a concern?
I assume this is a rough-in before basewment slab pour? Is the ground frozen? Thaw before pour. High water table? Take drainage precautions. Excess water run from somewhere else? Dry it out. Etc, InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Water softener drain or what? | rnewman1 | Plumbing Inspections | 3 | 4/26/07 10:08 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
