I inspected a house in about couple of months ago...and now the customer's calling me and telling me that when it rains the water stays in the backyard, and I don't know if he's exagerating or not but he says that the water level is like 5 inches or so...
There's a building deck with a jacouzzie attached to the house, the deck is filled with earth and no possible viewing of inspecting under the deck... What could be wrong... and even dough at the time of the inspection it was all dry how can an inspector could know about this? They also contacted the previouse owner and to them was normal and nothing was mentioned in the vendor's declaration. Any thought anyone..? |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Go out and look at it. It is possible that there is a drainage problem that was not visible when you inspected. Suggest that they put some type of drainage system in - usually a French drain will work. Hopefully, all they are looking for is guidance on how to solve a problem.
Any pictures of the original Inspection?
And I agree, go out and see what the problem is to compare what you reported at the time. Conditions might have changed. Deck full of dirt, what was the meaning of that statement? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
put a drain out in the yard to drain off the standing water. Remove the water at the source before you start digging up a foundation.
As for seeing this during dry conditions; vegitation often changes where standing water remains for extended periods of time. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I mean that under the deck is filled with dirth...and not empty.
I am going to see it this afternoon, and if i noticed any changes I will let you know.. And yes I do have pictures of the original inspection. |
Wow, don't know how water could pond on that landscape, but judging from the vegetation on the stairs and bulging deck skirting that is full of dirt, the ponding could be underneath that area.
My assumption is that he is referring the the 'lot' grading. There is most likely a 'dip' in the yard, and depending on the soils, it may take quite a while for the water to perk into the soil. Landscaping and lack of upkeep (lawn not mowed, etc.) can sometimes make it difficult to notice this.
agreed it could be heavy clay, Dennis R.Goudreau D.R.G. Inspections LLC www.newhampshirehomeinspector.biz www.nhinfraredthermalinspections.com http://co.nachi.org/inachiawards |
What you mean by a "dip"?
A depression.
PS... please update your profile to show your location. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
A small depression in the lawn area capable of holding water a few inches deep due to the clayish soils, low permiable grounds, and poor drainage characteristics.
Where does water from the two visible gutter downspouts discharge?
Jam Lasserton is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you don't go look at it have the owners send some pictures. If the are serious and it looks bad then go out there. It may not be a problem you can fix and may need other reinforcements. The owners may not upkeep their yard well either. If you get pictures, I am sure we would love to see what they are talking about.
| Hot water first then cold out of cold side of fixture | jberthiaume | Plumbing Inspections | 19 | 3/12/08 1:32 AM |
| smelly well water | afrost | Ancillary Inspection Services & Additional Topics | 26 | 11/21/07 7:30 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
