Old 9/19/07, 9:20 PM
Ted Allen Ted Allen is offline
Default We are talkin MOLD here
http://www.consumerreports.org/cro/h...g-rid-of-mold/
I am with Dave for the most part.
If you have a little bit of mildew on some surface areas you might get away with the bleach thing. However if you have real mold problems you need some help. Mold can be a very serious problem.
If I see mold I ALWAYS recomend a pro.
Old 9/23/07, 1:58 AM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: We are talkin MOLD here
It may be advisable NOT to use the word/term mildew in your inspection reports and or communications. Mildew is actually a type of mold. Realtors like the term because it sounds less alarming than "MOLD". However, without proper lab results and testing, you never know what type your dealing with....
Old 9/23/07, 2:55 AM
Barry Adair's Avatar
If I see mold I ALWAYS recommend a pro.
Todd,
What kind of pro and for how small or large an area? Not trying to put you on the spot, looking for the real facts.
Had this yesterday, 4' x 6' laundry room and adjacent 4'x 6' pantry had evidence of visible or attempt to paint over microbial growth. Visibly about 6" up all walls were affected whats behind who knows.
What would you say to a "new low budget family" already maxed out trying to get into the house.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/23/07, 3:17 AM
Joseph Hagarty,  CMI's Avatar
I would say the same to a "New High Budget Family" of a 3 Million Dollar + home.
You need to have the problem rectified.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 9/23/07, 3:37 AM
Joe,
The source of the problem has been rectified, no more water leak at the laundry.
Do you have further comments you include in your reports?
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/23/07, 9:44 AM
mdiplock's Avatar
mdiplock mdiplock is offline
Barry, the leak may have been fixed, but the mold problem still exist. What you are seeing there is less than a 1/4 of the actual problem. These are some pics of some remediation that started after an inspection a few months ago. Turns out the mold was growing behind the insulation and at least 6' up the walls and had spread to a large portion of the room. This ended up leading to more problems as they found that the floor drain was blocked from some previous amateur plumbing and had caused the water leak to spread throughout the subfloor and up other walls. The job went from $3,000 to over $20,000.
Moral of the story, Never, never downplay a mold problem and always recommend remediation.
a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself"
Regards,
Mark
Old 9/24/07, 12:28 AM
Ditto..
Old 9/24/07, 12:40 AM
Joe,
After the fact comments do not usually concern the HI, but if you are willing to go back and check someone elses work then you had best be prepared to be a specialist in that field. I did call backs,but only on things I was totaly confident about..........MOLD is not one of them............
What are you going to report? Yes, the leak has been fixed, but do YOU as a HI really know about the mold????
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Mold mcyr IAC2 Indoor Air Forum 5 9/13/10 10:31 AM
Mold Remediation & Duck Cleaning Work-If Done Right dplummer Ancillary Inspection Services & Additional Topics 8 10/12/07 2:03 PM
HI Encourages Mold Testing dplummer Ancillary Inspection Services & Additional Topics 10 10/2/07 4:14 PM
Everyday Events Can Cause Mold jmckenna1 Miscellaneous Discussion for Inspectors 1 3/3/07 2:11 PM
