Does anyone have a suggestions for the best website hosts /provider for HI companies ...... how does your perform?
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I use Yahoo and SiteGround. No problems with either.
Contact Home Inspector Pro. Dominic can't be beat when it comes to new sites and getting you in front of the search engines. A large variety of templates for you to pick from.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Agree, Home Inspector Pro is the greatest, as it is designed with SEO in mind. Saves a ton of work. I also use Inspectorsites.com but had to do alot (and more to do) for SEO. There are also many others available to choose from. Many inspectors create and host their own.
Troy Pappas Virginia Beach Home Inspector Professional home inspector serving Virginia Beach, Norfolk, Suffolk, Portsmouth, and Chesapeake 757-418-0944 |
If you want the best SEO possible , you use Home Inspector Pro.
One of my clients is a SEO expert ,and he told me he was amazed by how well the basic templates are pre loaded to show up on the search engines. |
| Website of the Year Nominations 2008 | mcyr | Miscellaneous Discussion for Inspectors | 0 | 7/18/08 9:45 PM |
