kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Inspection today had four layers of roof covering!
| Find an InterNACHI certified Connecticut Home Inspector (and anywhere else in North America) |
we are tied
Too many to count was mine.
Are you sure that's four layers? That bottom layer looks like a starter course. The third "layer" looks like it might be a starter course as well. If either of those are the case, then you have either 3 or 2 layers. (Still not good, but better than 4.)
I cant count this one, because it was back in the construction days....
3 layers of asphalt, and 2 layers of ceder shakes. I personally stripped this one, boy was it a PAIN in my tookus... |
I agree with Mark. It looks like 2 layers with a starter course at the bottom of each layer.
Scott Gilligan Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector #34206 President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Philadelphia, Pennsylvania real estate professionals on ActiveRain.com |
hth "Never underestimate the difficulty of changing false beliefs by facts." |
I wish I had some photos, but back in my roofing days, we found one theat had SEVEN layers on it. 2 layers of shakes, 2 layers of roll roofing and 3 layers of 3 tabs. Amazing the house didn't collapse.
Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network What we've got here is......failure......to communicate.....
Mine is six; a home built in the early 1900's; 2x4 oak rafters where so bowed that the home was unsafe. First layer was wood, followed by 5 layers of comp.
I thought that at first too but when I looked closer at the grain, they all had slightly different colors and wear.
That's only two layers kev.
"It's not what you believe that matters...it matters what you believe!" |
That means it had 4 layers done wrong.
Maybe it's in the guiness book of records??
I keep stacking until the roof sags, then sell! |
Looks like 2 to me... could be 3 with only one starter course.. dunno
I've seen experienced roofers and AHJ's make boo boos on site with counting layers... even harder to tell in pictures. Have seen Shake, then 30lb & rolled roofing Ridge was a bit saggy too. Was over an early type of built on site truss system with 2 x 6 top chords and plywood gussets. All got stripped and I saw the house not all that long ago. Lumber didn't straighten itself out btw. I've heard countless times "It'll straighten out once the weight is off" |
I count from the side , I do not count the starter row
| Pending Home Sales Plunge 4% to Record Low | jburkeson1 | Misc. Discussion | 0 | 1/6/09 12:10 PM |
| October Home Prices Post Record Decline | jbushart | Misc. Discussion | 4 | 12/26/07 5:01 PM |
| Dow Surges To Record High | jmckenna1 | Misc. Discussion | 25 | 4/24/07 10:40 PM |
