Can anyone tell me what this accumulation of the white powder is? It seems to be coming from the vent connector of the oil fired furnace. Is it some byproduct of the combustion or is it deteriorated clay liner working its way down the flue connector? Or could it be that the oil being burned is reused/filtered oil, containing some sulfites etc. - there is a reason to believe that the used oil was being burned.
Thanks PRIME INSPECTIONS Home Inspections in Delaware County NY, Otsego County NY, Chenango County NY, Chenango County NY, Broome County NY. I am a NY State Licensed Home Inspector lic.#16000041526 |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like zinc from the galvanized pipe. If there is condensation inside the vent from combustion gases or from moisture intrusion, it will turn the zinc coating to a white powder. Recommend a Level 2 to make sure there are no blockages or restrictions which would be causing poor venting.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Thanks, I did recommend level 2 inspection.
| White powder covering insulation in the attic? | wwilliamson | Interior Inspections | 12 | 3/14/10 7:13 AM |
| White Powder on Attic Trusses | jcooper2 | Ancillary Inspection Services & Additional Topics | 22 | 1/5/07 5:22 AM |
| White Powder Residue | kevin.raymond | Inspecting HVAC Systems | 1 | 9/26/06 6:04 PM |
