These pictures are from the wood flooring above the basement of a home built in 1930. What exactly is this white substance on the wood?
| Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America) |
Looks like white mold or the start of dry rot in the framing.
Some sort of fungi caused by the excessive moisture environment. Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
The wood looks like it was treated with creosote, which was a common way to do pest control years ago. You may want to add a disclaimer about that chemical possibly being present.
I agree...the white stuff looks like mold. Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Thanks gentleman.
Yeppers.
White rot.... most likely started, died out if not enough moisture was present. In spore form it will stick like glue to the surface, waiting for moisture. Q |
| White, chalky substance on brick? | rmaday | Exterior | 2 | 5/8/09 12:48 AM |
| White powdery substance | sjohns | HVAC | 13 | 1/31/09 12:13 AM |
| Treated Lumber Changes | jmckenna1 | General Inspection Discussion | 2 | 8/10/06 8:57 AM |
