Old 6/7/08, 10:40 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Default Why Waste Some Good Bricks?
Why Waste Some Good Bricks When You Can Put Them To Good Use...
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 6/7/08, 11:05 PM
James F. McKee's Avatar
Default Re: Why Waste Some Good Bricks?
think those were union brickies John ???
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 6/7/08, 11:15 PM
gbeaumont's Avatar
Wow somebody jacked up that air handler and stole its wheels
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/7/08, 11:21 PM
Some breakers were getting hot too...
Old 6/7/08, 11:22 PM
Regards
Gerry
Funny... that is exactly what it looks like...
This unit must be from New York..!
Old 6/8/08, 6:02 AM
David P. Valley's Avatar
All they need to do now is install sized strapping from the rafters to the unit, in order to properly suspend the unit. Then install a piped secondary condensation pan.
That'll correct this situation.
Old 6/8/08, 8:02 AM
James H. Bushart's Avatar
The contractor tried to explain to the owner "I only do HVAC....on the side."
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 6/8/08, 10:30 AM
Carl A. Brown's Avatar
Can not find enough bricks for full time work?
Old 6/8/08, 11:18 AM
I would have passed the brick work under the heating unit if they had just
added a few more bricks higher so the client could put their storage
items under the unit. It's hard to find good brick masons....
Old 6/8/08, 9:49 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Well I guess it's "easier" than using uni strut and Threaded rod if it's gettin close to beer 0'clock!
As far as stealing the wheels .... the unit would most likely be found in "Beautiful Chelsea by da sea"
OAHI Out Of Control - Bylaws Breached - Documented Proof rwand1 Canadian Inspectors 423 2/25/08 6:20 PM
Grounding -V- Bonding Article (Good Read) pdoane Electrical Inspections 0 10/12/06 4:31 PM
main waste pipe bking Plumbing Inspections 1 5/17/06 9:14 PM
Define "Indirect Waste Receptor" jfunderburk Plumbing Inspections 5 2/18/06 5:35 PM
