Old 5/24/11, 1:32 AM
Michael Prinsloo Michael Prinsloo is offline
Send a message via Skype™ to Michael Prinsloo
Please Note: Michael Prinsloo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Wire amapacities
Where do I get wire ampacities? Also according to one thread for the breaker sizing of the AC or heat pump, you can breaker for the maximum rating and wire for the minimum rating. Where do I find this information?
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/24/11, 7:22 PM
James E. Braun, CMI's Avatar
Default Re: Wire amapacities
I have never seen it in writing but about all heating and cooling contractors say that. It is acceptable in my area.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 5/24/11, 7:24 PM
Nick Gromicko's Avatar
http://www.nachi.org/gallery/electri...ge-ratings.jpg
Find a Home Inspector
Old 5/24/11, 7:39 PM
Jeffrey R. Pope's Avatar
General ampacities are outlined in the link posted by Nick. The NEC (or the Canadian version of the same) will give you much greater detail including wiring requirements for motors and such.
This info is available on the data-plate of the appliance.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/24/11, 7:44 PM
The wire size is on the data plate? When did they start doing that?
Old 5/24/11, 8:11 PM
Bruce A. King's Avatar
These two links and the code book should get you everything you need to know....
http://ecmweb.com/nec/code_calc_072304/
http://www.nachi.org/forum/f19/12-wi...-circuit-5629/
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 5/25/11, 10:04 AM
Not the wire size, the minimum and maximum circuit ampacity.
For instance, the minimum circuit ampacity may be rated at 28.8 amps, so it should be wired with conductors rated for at least 30 amps. Next to that, it will list the maximum breaker or fuse - let's say it says 45 amps.
So in this case, you can have a 45 amp breaker serving 10AWG conductors and the installation would be compliant with both the NEC and the appliance listing.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/25/11, 11:25 AM
Okay, thanks!
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Proper Marr Connectors for Aluminum Pigtails jskrypka Canadian Inspectors 5 3/25/07 10:41 PM
