Would you cut the ties and test the automatic opener?
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Winterized/forclosed property?
I would not cut them unless I could replace them. I find locks and pins but no wire ties yet. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
The other day I had a 3/4" drill bit that was drilled into the door and broke off....and I do carry zip ties so I would cut it and then replace them.
It looks like the way the zip ties are positioned that the door could be raised about 2 feet before they caught the next roller.
prolly
What if the door falls off the track, and someone did this to prevent it. You could just note findings, and get on with the inspection. Did they hire you to fix things ?
I wouldn't, for the same reason our SOP says we don't turn on valves that are turned off. The best way I've found for me is to highlight these items when going through the contract signing with the client. For example," I don't check lawn sprinklers, alarm systems, hot tubs, I don't turn on valves that are turned off, I don't light pilot lights that are off, so on & so forth""" That way they were aware of these things in case they didn't retain they info when they sped red the contract....
NACHI #03120124 www.aplushomeinspections.net Proundly Serving S.E. Wyoming & Western Nebraska "Learn from the mistakes of others, Life is to short to make them all yourself" |
Don't know for an absolute fact why they were installed in the first place, so no, I would not remove them and defer the door and opener.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Yes I would Gary, and I do about twice a week.
I have new ones in my truck to put back on. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
yes.
Only after a thorough inspection of the door hardware, springs, and track brackets etc..
One more reason to inspect the door before engaging the opener. Those ties could do some damage if overlooked. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I cut it and operated the door.
Only if it can be left in the condition it was found in.
gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
No way , people do not secure a garage door for no reason, I had one a couple weeks ago that had a 2x4 nailed on the header and the opener was unplugged so I just reported it as such.
Yes.
Bill Emelander Professional Edge Home Inspection Grand Rapids and all of West Michigan NACHI #03111914 www.proedgehi.com |
