Old 10/31/08, 5:30 PM
Steve A. Rinner Steve A. Rinner is offline
Default how would you report this?
found this in a duplex I inspected today. It is a radiator under the kitchen sink. The tennant has piled several items on and around it as you can see.
Thjanks in advance
Old 10/31/08, 5:31 PM
mnahrgang's Avatar
Default Re: how would you report this?
I wouldn't "report" it at all. I would tell my client it's not a good idea though, and why.
Mark Nahrgang
www.HeyMark.info
Old 10/31/08, 6:22 PM
James F. McKee's Avatar
I don't think I would report this either Steve unless you saw something there that was really flammable at low temperature...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/1/08, 12:34 PM
jkogel jkogel is offline
I would report the old brass drain pipes, recommend upgrading of the drain, and report poor location, recommend removal or relocation of the radiator. In the summary - Monitor.
John Kogel
www.allsafehome.ca
Old 11/1/08, 12:44 PM
dmcauley's Avatar
dmcauley dmcauley is offline
Please Note: dmcauley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just going by the picture, I also would not report it. Looks like a "housekeeping issue" more than safety. As Mark stated, I would inform the potential buyer to try to keep things away from the radiator as much as possible. I would also not report that the radiator is in a poor location either. The house looks older and they may have had the radiator installed there to keep pipes from freezing , since you are in Ohio.
What did you do on this?
Last edited by dmcauley; 11/1/08 at 12:45 PM.. Reason: I can spell, I just can't type too good.
Old 11/4/08, 4:12 PM
tchristopher tchristopher is offline
I would feel the drain trap at the bottom of the curve, or look up at it if possible to check for corrosion on the bottom where water stands to create the seal, as the photo looks like there may be some corrosion/rust on the side of the pipes so if its there its probably worse on the bottom, I would advise to keep everything off & away from the radiator as these do get hot to the touch some times depending on conditions. It's very possible they never use the radiator also.
NACHI #03120124
www.aplushomeinspections.net
Proundly Serving S.E. Wyoming & Western Nebraska
"Learn from the mistakes of others,
Life is to short to make them all yourself"
Old 11/4/08, 4:29 PM
czornes czornes is offline
All you guys are new at this I can see. Well, as a contractor I know this is a water heater!
Old 11/4/08, 4:36 PM
Wayne B. Wilson's Avatar
I dont believe it is a water heater, it is a rad for the heating system though
Old 11/4/08, 5:14 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Was it plumbed and functioning?
Old 11/4/08, 6:01 PM
klott's Avatar
klott klott is offline
What kind of WH is designed to release it's heat into the air?
"It's not what you believe that matters...it matters what you believe!"
Old 11/4/08, 6:37 PM
bdoles2's Avatar
I believe Mr. Zarnes was busting balls about the water heater comment.
Old 11/11/08, 6:22 PM
John V. Wantz John V. Wantz is offline
Are you a painting contractor?
Old 11/13/08, 7:55 AM
Cool Re: how would you report this?
YES, I was poking fun at the picture.
And no not a painting contractor but a Certified General Contractor in four states.
New Report Upload Technology cdemsky Miscellaneous Discussion for Inspectors 49 5/1/07 10:19 AM
