Old 9/19/07, 3:20 PM
gporter's Avatar
gporter gporter is offline
Default How would you write This
Need help on how to write this one.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 9/19/07, 4:05 PM
wsiegel wsiegel is offline
Default Re: How would you write This
Gary,
Being up un the Orlando area, is that EIFS? Block or wood construction?
Either way, you probably have water penetration behind that. Did you check the interior walls. Even though I hate the term "further evaluation" that area will need to be pulled off to determine the extent of damage. I would recommend repair by a licensed stucco (or EIFS) contracator and recommend that they inspect the entire system around the house.
Old 9/19/07, 7:42 PM
Peter Doane's Avatar
Looks like the exterior finish coat (usually a Portland Cement base) is cracking at the block seams, typically a cosmetic item. Usually not a huge issue. What did the other side look like? Any deflection, bowing out etc.?
Peter Doane
NACHI ID# 05120681
Old 9/19/07, 7:49 PM
Mathew Hawley Mathew Hawley is offline
From the photo it looks like settlement cracking. I would recommend they seal and paint all exterior voids to prevent water/moisture intrusion.
It's hard to tell by just the photo.
Old 9/19/07, 11:40 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Looks like a block wall with minor cracks UNLESS the blocks go below
the ground level and the cracking allow moisture into a basement or crawlspace.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 9/20/07, 12:08 AM
John Cahill John Cahill is offline
Exterior surface has cracks. Have structural and exterior materials specialist determine cause and need for repair.
Your job is done. Follow up with them to find out what went wrong and how they fixed it.
Old 9/20/07, 12:10 AM
Maybe also impact related.
Old 9/20/07, 12:24 AM
William M. Corbett's Avatar
William M. Corbett William M. Corbett is offline
I agree. No need to call a specialist if there is not any deflection.
Bill Corbett C.H.I.
Magic City Inspections LLC
InspectingtheUnexpected.com
Old 9/24/07, 1:48 AM
Ted Allen Ted Allen is offline
Stucco Cracks.....................
Old 9/24/07, 1:02 PM
Carl A. Brown's Avatar
And when it cracks over block it follows the lines in the block most often.
Why does the wall look wet?
The sprinklers should never hit the wall!
If they used moisture barrier and lath over the block you would hardly ever see that /those cracks.
Old 9/24/07, 2:39 PM
Rick Henderson Rick Henderson is offline
Please Note: Rick Henderson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey there kind of new to the message board. My two cents worth. What I find interesting is the shape. It almost looks like both sides of the wall are pulling away. Were the outer corners of the wall still plumb? The wall does look wet if that horizontal crack at the top came first and they let water get in it might have wicked itself and weaken the masonry joints of those bottom blocks.
Old 9/24/07, 3:30 PM
I am to a member.
Old 9/24/07, 3:38 PM
Michael Larson's Avatar
Originally Posted by Rick Henderson
I am to a member.
If you log in with the correct login information you will show up as a member.
Contact:
fastreply@nachi.org
if you have problems.
AHJ's opinion differs from code...how would you write it up? jhugenroth Plumbing Inspections 9 8/31/09 9:04 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 124 4/27/07 12:05 PM
Write It up or not? thejnicki Electrical Inspections 5 8/7/06 4:49 PM
How should I write this gporter Inspecting HVAC Systems 7 6/29/06 4:27 PM
How should I write this gporter Exterior Inspections 11 4/15/06 10:39 PM
