, or this , or this , or this ?"Are you qualified to inspect this?" These six words may stop a capable inspector in his/her tracks. It requires:
Your Answer: "YES. I am HVAC Trained by InterNACHI." Are YOU qualified? Two-minute commercial about HVAC Training Online Video. |
Quote Ben Gromicko: Identification of system efficiency (60-65%, 80-85%, 90-95%) End Quote: Ben, I remind you of the NACHI Standards of Practice. NACHI RESIDENTIAL STANDARDS of PRATICE 2.4. Heating I. The inspector shall inspect: A. The heating systems using normal operating controls and describe the energy source and heating method. B. And report as in need of repair heating systems which do not operate. C. And report if the heating systems are deemed inaccessible II. The inspector is not required to: A. Inspect or evaluate interiors of flues or chimneys, fire chambers, heat exchangers, humidifiers, dehumidifiers, electronic air filters, solar heating systems or fuel tanks. B. Inspect underground fuel tanks. C. Determine the uniformity, temperature, flow, balance, distribution, size, capacity, BTU, or supply adequacy of the heating system. D. Light or ignite pilot flames. E. Activate heating, heat pump systems, or other heating systems when ambient temperatures or when other circumstances are not conducive to safe operation or may damage the equipment. F. Override electronic thermostats. G. Evaluate fuel quality. H. Verify thermostat calibration, heat anticipation or automatic setbacks, timers, programs or clocks. 2.5. Cooling I. The inspector shall inspect: A. The central cooling equipment using normal operating controls. II. The inspector is not required to: A. Determine the uniformity, temperature, flow, balance, distribution, size, capacity, BTU, or supply adequacy of the cooling system. B. Inspect window units, through-wall units, or electronic air filters. C. Operate equipment or systems if exterior temperature is below 60 degrees Fahrenheit or when other circumstances are not conducive to safe operation or may damage the equipment. D. Inspect or determine thermostat calibration, heat anticipation or automatic setbacks or clocks. E. Examine electrical current, coolant fluids or gases, or coolant leakage. But… to answer your question my answer would be ….. Yes…. Because…. I stayed at a Holiday Inn Express last night! All kidding aside.... the two minute video looks highly professional! Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
I wouldn't hire a home inspector who couldn't identify the efficiency type, particularly in this day and age of fuel costs and green building. Last edited by bgromicko; 11/24/08 at 5:14 PM.. |
As "Buckwheat" used to say.....OTAY! Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
Im wondering if the SOP should be updated...considering the comments afforementioned.
No. SOP is a minimum. And should stay that way.
In contrast, training and education should go beyond the SOP and minimum requirements. If I need a doctor, I want the best trained doctor that I can afford. I don't want that doctor to tell me that all of the training and education that she knows DOES NOT EXTEND beyond the minimum that is expected. Last edited by bgromicko; 11/25/08 at 12:36 AM.. |
AGREED! ![]() Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
Looks like a great educational video....Cant wait to watch.
| Experienced, qualified Help Wanted | Bill Mullen | Canadian Inspectors | 0 | 10/21/07 4:46 PM |
| Qualified Educators are always welcome... | bmerrell | Inspection Education & Training | 7 | 7/15/07 12:08 PM |
| IL State or other FHA qualified inspectors | kkenny | Miscellaneous Discussion for Inspectors | 2 | 10/23/06 8:41 PM |
| EMF qualified inspector needed in Brooklyn, NY | lendza | Miscellaneous Discussion for Inspectors | 3 | 7/25/06 3:22 PM |
