Hello all, I've been an HI for about seven months and constantly learning. For my own research purposes I was curious to what are the most common findings. It'll be interesting to see how they differ in each part of the country. For example, here in Louisiana we don't worry about ice dams but we have our own crawl space issues. List your five most common findings.
Colton Hagler LSBHI #10760 Scope Home Inspections Colton@ScopeInspections.PRO www.ShreveportHomeInspections.net Home Inspector Shreveport |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No High Loop/Air gap at the Dishwasher
No Drip pan on for the Water Heater in the Garage Broken Roof Tiles Missing Anti Siphon valves on exterior Hose Bibs Toilets not secure to the floor properly. |
roofing boots cracking or worse
foundation cracks open grounds GFCIs s traps |
no anti siphon
double tapped fuses loose handrails no faucet shut offs loose toliets |
Pan under the water heater in a garage? Are we worried about the concrete getting wet? Is this a regional thing? This is standard practice here
Inspecting Norfolk and Hampton Roads www.procraftinspections.com Energy Audits in Norfolk www.procraftgreen.com |
Ditto.
No high loop on the DW
No anti-tip on the range Stair rails not continuous Stair rails not graspable Pickets > 4" “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
:d :d :d
Flippers that are floppers and have no clue how to do plumbing and electrical
Home owners modifying systems/improper handyman installation electrical, and a lot of other systems and messing them up. Unpermitted work - lots of finishing being dome improperly in attic/basements. Water Infiltration - inferior basement systems, poor grading, poor roof drainage, leaking flashing. Heating/Cooling systems lacking service/dirty filters Then there are the typical almost everyday items that others have mentioned. Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
In no particular order:
minor issues - from a cost or labor view Drainage close or toward the house Exposed romex - mostly in basements and at disposal Open grounds at 3-prong outlets Neutral/ground doubletaps at main busbar Overfused circuits Major issues - again from cost or labor Outdated/unsafe furnaces which need replaced - for many many reasons Horizontal foundation cracks and related bulging due to hydrostatic pressure and frost heaving Mold in attics and basements - usually due to overall crappy moisture control Structral modifications - and the resulting movement or damage Moisture intrusion into basements - this varies in cost and labor but it can get expensive quick Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
1. My agent says a home inspection should only cost $250
2. My agent says the inspection will take about an hour no more than an hour and a half. 3. My agent says it is an "as is sale" and I don't really need an inspection. 4. My agent says it's a new home and the City Inspector has already passed it. 5. My agent can't make it to the inspection do you need them to unlock the house? Other than that; 1. No air gap at dishwasher 2. No AFCI 3. No GFCI 4. Leaking mastic at air handler 5. Drainage issues George Russell George Russell Professional Inspections Austin,Texas TREC # 10215 512-296-9538 http://georgerussellprofessionalinspections.com/ http://www.facebook.com/austinhomeinspections |
A/C ducts doing loop deloops in a run
improper tpr relief piping installation Double taps Bad stucco/ flashing on stucco Rot These are the most common, 1/2 at least all the time on 1/2 the reports. |
did you know that many dishwashers have a high loop attached to the unit under the insulation before it even enters the sink cabinet?
exposed romex? whats wrong with that? you need everything in conduits in Illinois?
Not conduit just "protected", per the NEC. So running down the walls in the basement and hanging below the kitchen sink to the disposal isn't allowed.
And those first five are great George! Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
| Common Roof Defects found during inspection | tspargo | Roofing Inspections | 8 | 12/24/11 9:57 PM |
| Common wall of garage is Laundry room / firewall ? | dnasser | Interior Inspections | 14 | 6/26/09 11:57 PM |
| Slab Cracks common in 20 year old homes? | Seth Williams | Structural Inspections | 16 | 5/6/07 5:47 AM |
