Old 7/30/07, 6:47 PM
Craig Collier Craig Collier is offline
Please Note: Craig Collier is a non-member guest and is in no way affiliated with InterNACHI or its members.
Angry Yup.. still hot!
I'm melting!!! this is an attic temperature from today.
Old 7/30/07, 11:12 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Yup.. still hot!
Nice sauna!
Old 7/31/07, 5:42 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Wow! Bet you weren't up there 3 minutes. I was up in one 120 degrees a few weeks ago for about 10-12 min and started getting dizzy. definitely going to change my routine. that's ridiculous. attics before 10 and after 7:30, if possible.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 7/31/07, 5:43 PM
what's their utility bill like?
Old 7/31/07, 6:19 PM
Don't stay up there too long...I remember pulling a roast out of the oven, done, about that temperature over the last Christmas holidays.
Larry Kage, CMI
231 929 3525
Old 7/31/07, 6:23 PM
I was up there for about 10- 15 min. When I came down I looked like I had fallen in the swimming pool.. I took about a ten minute break to re-hydrate.. AHH.. Arizona, ALWAYS bring plenty of fluids to inspections around here.
Old 7/31/07, 6:40 PM
Pretty common here, too.
Abraham Lincoln
Old 7/31/07, 7:12 PM
phinsperger's Avatar
If its too hot I would have a look from the access and offer to come back in the evening at no additional charge to thoughly inspect the attic. If you go up in that heat you are no doublty making it a very quick inspection.
If you were to colapse from the heat, how much longer would you be up there before the ambulance showed up?
Also I would expect the homeowner to hold you responsible for any damage the emergency crews may have done to get you down. Not mention an unhappy client and realtor who never got the inspection finished that day and all the additional time waiting for the emergency crews to clear out.
I suppose if you are in the south you're used to those temperatures and can tough it out without a problem - good for you. But if you think that it may just be a bit too much, then please for your safety, think again.
2.9. Attic, Ventilation & Insulation
II. The inspector is not required to:
A. Enter the attic or unfinished spaces that are not readily accessible or where entry could cause damage or pose a safety hazard to the inspector in his or her opinion.
Old 7/31/07, 7:31 PM
tdietrich1's Avatar
160F about what my attic is like at times.
BTW, I suspect IR therms are more sensitive to 'heat'. Follow me, the heat is coming from the roof sheathing and transferring into the air. So naturally the sheathing is the hottest item, even with good air flow, it's hot and the IR therm is reading it, not air. The air temp could be quite comfortable, say 120's?
tom
Old 7/31/07, 8:46 PM
I don't know about the rest of the guys around here or in AZ, but the A/C in my house is set at 82 degrees. Any lower and it's just too chilly in the summer!
Tom is right, the infrared picks up the sheathing temp very easily. 160 to 175 is pretty common in the sun with a dark colored roof covering, and the attic air temp is usually quite a bit lower, around 140 or so.
Now as for you northerners in the winter, sheeesh!! I would have to disclaim the entire outside and tell them I'll be back in the summer.
Abraham Lincoln
Old 7/31/07, 9:07 PM
I'm with you Blaine....... I don't even know where to start with a Snowy exterior.. and a Cold, damp crawlspace filled with wild animals and such... It has been over a year since I have even had a home with a crawl space!! I guess there are some good things and some bad things about everywhere.. and just for the record, the air temp in the attic was about 142. But it was a dry heat!
Old 8/2/07, 1:02 PM
kmiller1 kmiller1 is offline
Should have pulled out at 125-135
Old 8/2/07, 1:06 PM
Jeez. That's what they make Carharts for.
Old 8/3/07, 10:21 AM
Barry Adair's Avatar
yesterday at 7am passing through Grapevine, TX
not sure if it was 132 or 182
just seeing this made me want to turn around and go back to the pool
wait this can't be and it wasn't i just remembered this thread and thought about the troops enduring temps well above what we encounter day after day
let's count our blessings
we get to choose where we go and what we do, they do not!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 8/3/07, 10:39 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
I like the cold and start sweating when it's over 72.
Man was meant to thrive in cooler weather,and go to retire and die in the heat.
