1. Cracks in concrete foundations and open voids in concrete foundations.
2. Any wooden posts or supports set in concrete that may be in contact with the soil underneath. 3. Concrete porches with earth fill that may provide wood-to-soil contact. 4. Form boards left in place. 5. Leaking pipes and dripping faucets in the crawl space that keep the soil under the structure moist. 6. Blocking crawl space vents with shrubbery that causes the air under the structure to remain damp and warm. 7. Construction debris in the backfill beside the structure. 8. Low foundation walls and footings that provide wood-to-soil contact. 9. Stucco or brick veneer carried down over the concrete foundation. 10. Soil-filled planters built up against the side of the structure. 11. Forms left in slabs, where plumbing drains enter the structure. 12. Wooden porch steps in contact with the soil. 13. Heating units in crawl spaces that maintain warm soil temperatures. 14. Paper collars around pipes and ducts. 15. Wooden fences, trellises and other wooden adornments up against the side of the structure. BEN GROMICKO InterNACHI Director of Education 'Now That You've Had a Home Inspection' Book Home Inspection Training Video on USB |
| Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America) |
WDI.......
kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's a bug buffet. Pass the salt please.
Ben;
Add to that any cellulose concrete peir tubes (for the forms). Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
My License does not cover WDO, so I can not render a determination on any O's.
Huh. You can't report on wood rot?
Damaged wood, sure, the orginism that caused it????????
More than likely wood rot was caused by water. |
At least you didn't post "... the orgasm that caused it?????" Hope this helps; (eh, not really Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Sorry, I should have said: You can't report on brown, white or soft rot fungi?
In the Desert???? You have cable TV don't you?? |
Lol None of that down there huh?
Every now and then, but think about it, how much water do you imagine it might take to support fungi in the Desert???
Every now and then there is some cool stuff growing on a patio cover. |
| Lead Paint Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 4:27 AM |
| Lead Legislation Update | mkyriacou | Plumbing Inspections | 1 | 12/22/08 11:21 PM |
| Can buyers claim damages from lead paint if none exists? | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 0 | 8/15/08 2:00 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 4:38 AM |
