These concrete wall panels were interesting and new to me.
There was a bottom plate, then a c-channel with the refab panels inserted into it, then another c-channel with a top plate last. Between the panels was some okum type material with a tar that was applied inside and out on the joints which was still in good shape. I thought others would be interested too. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America) |
I have never seen anything like it Larry...was it in a home or commercial building?
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
A 1400 sq. ft. ranch home, Dale but it must not have caught on because it is the first and last I've seen. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Hi Larry,
Interesting "Tilt-up" construction, I have never seen that type of system employed on a residential structure, it's much more common in Commercial building however, back in the 50's when housing was going mad many companies (Lustron & others) developed panelized construction methods to speed up build times. I have seen a few oddities over the years and suspect that many of them were from smaller regional manufacturers, or in your case probably an attempt by a local concrete casting company to expand and diversify. Do you have any exterior shots for me to add to my collection? Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thanks for the information, Gerry. A small company was what I thought, too. One of the carpenters on site remarked how soft the concrete of it was. He cut some of it with a regular sawzall blade. Quote:
I wanted some outside pictures, too, but it was furred out with 1x3 and covered with fiberboard lap siding. I could see a small area where the meter and service drop had been removed but that was all. Sorry. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Hi Larry
Interesting Larry, never saw anything like it.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Yes, if it had been an inspection of mine I would have commented similarly.
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
