December 9th and 10th at the Holiday Inn-Select, in St. Peters, MO....the NACHI Caravan pulls in from Canada to offer another great session. Both classes start at 8:00 a.m. and run to 3:30 p.m. Fees are $50 for NACHI members and $100 for non-members.
For more info, see our chapter website at www.monachi.org Day One - 12/9 is Plumbing for Home Inspectors. Here is the outline: Plumbing Course Outline - 1 Day (6 CEUs) Course Overview: Purpose Elements Application Testing Evaluation Note: As a pre-requisite, the inspector should have clear understanding of their association’s Standard’s of Practice and Code of Ethics and/or their State/Provincial inspection guidelines, where applicable. Plumbing Introduction: Definition of Plumbing Components of Plumbing – Water Supply, Drain, Waste, Venting, Fixtures, Appliances, etc. Standards of Practice - Refer to Industry Associations Code of Ethics - Refer to Industry Associations Inspection Tools & Application Inspection Techniques, Safety, Reporting Methods & Qualifying the Client Types of Plumbing: Materials Used in Plumbing – Copper, Lead, Galvanized, ABS, PVC, Pex, Poly-B, Combination, etc. Pros & Cons of Each Type Styles of Plumbing: Designs – City (Municipal) vs. Rural (Private) Application - Soldered Joints vs. Compression or Crimped Pros & Cons of Each Style Combining Styles - Common Combinations - Considerations Plumbing Systems: Water Supply – Curb Stop, Main Shut-off, Water Meter, Distribution Pipes Drainage – Main Clean-outs, Stack, Traps Venting – Dry vs. Wet Cisterns, Wells & Septic Systems Mechanicals – Hot Water Tank, Expansion Tank, Pumps, Humidifier, Appliances Valves, Fixtures, Faucets, etc. Plumbing Pluses: Frost-free, Anti-siphon devices, Isolation Valves, Steel-braided Hoses, Insulation, etc. Plumbing Deficiencies: Defect Recognition - Recognizing Problematic Areas, Workmanship Quality, Weather, etc. Reporting Concerns & Issues for the Inspector Question period / Open forum Evaluation: Course Evaluation form handed out for completion & return (includes comments & suggestions) Day Two - December 10 is Framing for Home Inspectors. Here is the outline: Framing Course Outline - 1 Day (6 CEUs) Course Overview: Purpose Elements Application Testing Evaluation Note: As a pre-requisite, the inspector should have clear understanding of their association’s Standard’s of Practice and Code of Ethics and/or their State/Provincial inspection guidelines, where applicable. Framing Introduction: Definition of Framing Components of the Framework – Structural Supports, Floors, Walls, Ceilings, Roofs, etc. Standards of Practice - Refer to Industry Associations Code of Ethics - Refer to Industry Associations Inspection Tools & Application Inspection Techniques, Safety, Reporting Methods & Qualifying the Client Types of Framing: Materials Used in Framing - Wood, Metal, Combination Pros & Cons of Each Type Styles of Framing: Designs of Construction – Stick Built & Balloon Pros & Cons of Each Style Combining Styles - Common Combinations - Considerations Framing from the Ground & Up: Support Beams & Posts, Sill Plate, Rim/Band Joist, Floor Joists, Blocking, Sub-floor Wall & Nailer Studs, Cripple & King Jacks, Headers/Lintels, Upper & Top Plates, Wall Sheeting Ceiling Joists, Rafters, Trusses, Roof Sheeting Framing & Next Steps: Insulation, Vapour Barrier, Framing Deficiencies: Defect Recognition - Recognizing Problematic Areas, Workmanship Quality, Weather, etc. Reporting Concerns & Issues for the Inspector Question period / Open forum Evaluation: Course Evaluation form handed out for completion & return (includes comments & suggestions) James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you guys need an RSVP? I have a family member that may be released from the hospital that day. I may be needed and will not know until Friday.
What do you need as proof of NACHI membership? |
Jeff,
I would guess you could PRINT off this page showing the NACHI Member part under your name......that would probably work or the NACHI ID Card.....but mine has expired...lol Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I would GUESS that that would work......theehhee...
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 225 | 10/18/11 7:54 PM |
| How To Stop Your Home Inspection Clients From Suing You! | rray | General Inspection Discussion | 17 | 6/4/08 3:22 PM |
| CMHC recommending CAHPI National | rwand1 | Canadian Inspectors | 46 | 3/20/07 9:54 PM |
| Certified Well Sampler Training in St. Louis | jbushart | General Inspection Discussion | 2 | 9/11/06 9:50 AM |
| Denver NACHI Certified Training Seminar a Success! | trausch | Inspection Education & Training | 2 | 6/26/06 4:14 PM |
