Old 7/23/11, 5:23 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default What is this???
The home was built in 1977. This pit, is located in the basement. It is now a putting green. There is sump pump in the bottom. Maybe a LAP pool?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/23/11, 5:45 PM
Eric W. Augustin's Avatar
Eric W. Augustin Eric W. Augustin is offline
Default Re: What is this???
Hard to say, maybe a DIY hot tub? A lap pool is a good thought too. Are there any water jets we can't see?
Eric W. Augustin
A1 Certified Home Inspections
If you can't explain it simply, you don't understand it well enough.
Albert Einstein
Old 7/23/11, 5:56 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
That is a church baptism pool.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 7/23/11, 6:35 PM
Lap pool. Seen a couple of these around. All do not work. Suggest fill-in.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 7/23/11, 7:41 PM
It is covered with indoor/outdoor carpet. It is approx. 4 feet deep.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 7/24/11, 3:11 PM
I'll bet there are water jet holes under the carpet. It quit working, so they turned it into an unusual putting green.
Eric W. Augustin
Albert Einstein
Old 7/25/11, 12:48 AM
Lawrence W. Losciale's Avatar
Lawrence W. Losciale Lawrence W. Losciale is offline
It's what is called an endless pool/spa. They not only usualy have spa jetts but they also have "swim jets". Jets powerful enough to creat a current to swim against making a kind of water tredmill. They still advertise them on TV. This one has been drained and repurposed in to a putting green. It happens offten becuase the ones you see on TV aren't designed well.
