Due to the ever increasing number of home playgrounds and recent updates from the CPSC I have started including this info along with an explaination that none of the equipment present was inspected.
Consumer Product Safety Commission Home Playground Safety Tips CPSC Document #323 http://www.cpsc.gov/CPSCPUB/PUBS/323.HTML Each year, about 200,000 children are treated in U.S. hospital emergency rooms for playground equipment-related injuries - an estimated 148,000 of these injuries involve public playground equipment and an estimated 51,000 involve home playground equipment. Also, about 15 children die each year as a result of playground equipment-related incidents. Most of the injuries are the result of falls. These are primarily falls to the ground below the equipment, but falls from one piece of equipment to another are also reported. Most of the deaths are due to strangulations, though some are due to falls. 1. Protective Surfacing - Since almost 60% of all injuries are caused by falls to the ground, protective surfacing under and around all playground equipment can reduce the risk of serious head injury. Falls on asphalt and concrete can result in serious head injury and death. Do not place playground equipment over these surfaces. Also grass and turf lose their ability to absorb shock through wear and environmental conditions. Always use protective surfacing. Certain loose-fill surfacing materials are acceptable, such as the types and depths shown in the table. Certain manufactured synthetic surfaces also are acceptable; however, test data on shock absorbing performance should be requested from the manufacturer. Fall Height In Feet From Which A Life Threatening Head Injury Would Not Be Expected Type of Material 6 "Depth 9 " Depth 12" Depth Double Shredded Bark Mulch 6 10 11 Wood Chips 7 10 11 Fine Sand 5 5 9 Fine Gravel 6 7 10 2. Use Zones - A use zone, covered with a protective surfacing material, is essential under and around equipment where a child might fall. This area should be free of other equipment and obstacles onto which a child might fall. Stationary climbing equipment and slides should have a use zone extending a minimum of 6' in all directions from the perimeter of the equipment. Swings should have a use zone extending a minimum of 6' from the outer edge of the support structure on each side. The use zone in front and back of the swing should extend out a minimum distance of twice the height of the swing as measured from the ground to the swing hangers on support structure. 3. Swing Spacing - To prevent injuries from impact with moving swings, swings should not be too close together or too close to support structures. Swing spacing should be:
4. Elevated Surfaces - Platforms more than 30" above the ground should have guardrails to prevent falls. 5. Potential Head Entrapment Hazards - In general, openings that are closed on all sides, should be less than 3 1/2" or greater than 9". Openings that are between 3' 1/2" and 9" present a head entrapment hazard because they are large enough to permit a child's body to go trough, but are too small to permit the head to go trough. When children enter such openings, feet first, they may become entrapped by the head and strangle. 6. Potential Entrapment and Strangulation Hazards - Open "S" hooks, especially on swings, and any protrusions or equipment component/hardware which may act as hooks or catch-points can entangle with children's clothing and cause strangulation incidents. Close "S" hooks as tightly as possible and eliminate protrusions or catch-points on playground equipment. 7. Pinch or Crush Points - There should be no exposed moving parts which may present a pinching or crushing hazard. 8. Playground Maintenance - Playgrounds should be inspected on a regular basis. Inspect protective surfacing especially mulch, and maintain the proper depth. If any of the following conditions are noted, they should be removed, corrected or repaired immediately to prevent injuries:
CPSC Public Playground Safety Handbook http://cpsc.gov/cpscpub/pubs/325.pdf ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Nice info big B
Now we know who spends all his time at the playground, ha. ha.
Nice, Grandpa. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks Barry.
For those who didn't go to the link, here is chart. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Good info,thanks Barry.
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good info.
I don't quite get the chart though. A 4 or 5 year old falling from 11 feet onto any surface could produce serious injuries. I would define serious as an injury that is not life-threatening, but rather life altering in such a way as to require continued medical care or other hardship (ie. paralysis) I know the chart deals specifically with "life threatening injuries" and more specifically "head injuries", but I think it could be misleading in the fact that people may think their children are "safe" with the recommended materials. I haven't read the whole article - just saw the chart - but I would imagine the depth of material at "some point" becomes very compact and won't "give" 12" of fine sand - for example. I say this not as a liability issue, but a true safety/educational issue. *edit* I will add that all of the other info is top notch, the chart does bother me, though *end edit* |
How ever did we manage to survive? I'm not knocking playground safety but I find it amazing how the things have changed. Since I don't think we are any smarter now than then I can only assume that that we as a culture are are less and less willing to take on personal risk and more and more willing to blame someone else when accidents happen. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
If you don't do a physical inspection on the equipment, but just include pertinent safety information, that cannot be considered going beyond the SOP, can it?
The girls were really tough at my grade school. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
I remember very distinctly a childhood friend (we were 8 or so) falling from a 8 foot or so slide face down on to the pavement. There was a firehouse right next to the "playground" which I ran to for help. Quote:
Not that I haven't made similar comments, when my son was born, about car seats, playpens, walkers, etc. The reality is that while "we" survived, there are many that didn't because of the lack of safety awarness. I cringe when I see kids riding bikes without a helmet, even though I never owned one 'till recently. "From January 1990 to August 2000, CPSC received reports of 147 deaths to children younger than 15 that involved playground equipment." from http://www.playgroundsafety.org/research/index.htm Quote:
</IMG> |
