What would you charge to make a decal of this?
INSPECTIONLOGOS.COM "I can keep explaining it for you, but I can't understand it for you". Nick G. Monroe Home Inspection |
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Unfortunately that decal would be hard for me to make, sure I could do it…however the vinyl would be stacked to get the layers/colors. The world part would not work on my system. I can cut just about anything out in vinyl, the key is to try and keep it one layer one color if you can…
also when you cut out vinyl if you have an open area that gets cut out what ever to stick it too that back ground color will also show....
email me the logo and I will play with it and see what I can do with it....bsmithproroof@aol.com
Sent. If you can't you can't but Now I understand better what you can do and will use you for some other projects. If I'm going to spend the money I would rather it go to a Nachi member.
I don't know the decal business thats why I asked Brian. It may be better to have it made into a sticker. What you think?
| CPSC Recall- A.O Smith Water Pump Motors | pabernathy | Electrical Inspections | 0 | 6/24/08 7:13 PM |
| CPSC Recall- A.O Smith Recalls Water Pumps | pabernathy | Plumbing Inspections | 0 | 6/24/08 7:11 PM |
| A.O. Smith water heater recall | Gary Reecher | Inspecting HVAC Systems | 0 | 4/3/08 11:18 PM |
| AO Smith Recall | ldapkus | Plumbing Inspections | 2 | 4/3/08 7:01 PM |
