Will include suggested reporting language. Should be released this weekend.
NACHI's current SOP disclaims chimneys and fireplaces. Are you unilaterally implementing a change to that?
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
No it is just a suggested reporting language
Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
All inspectors will see standards of practice changing, adding more detailed verbage, all to get you to pay for classes to learn about home systems. See nachi.tv for examples. HVAC, infrared, ducting, electrical, now chimneys. See Dan's thread under state legislature about Kansas home inspection classes. This industry is changing rapidly, all to get you to pay for courses that are way beyond the standards of practice. That is why the SOP's are changing. Another marketing way for agencies to make money. And, it is not fair to us home inspectors who are all hanging financially by a thread. I have an interview with a large company tomorrow. I have to make money. I cannot pay for fees, classes, tools, and technology to keep up. Good luck to the rest of you.
Not according to Nick, Frank.
It is an SOP that "will include" suggested report language. "Standard" procedures published by a home inspection association are exactly that. Standard. My question to Nick is whether or not NACHI now requires in an SOP the inspection and reporting on fireplaces and chimneys. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
James, perhaps Nick wants to market chimney video/scope equipment.
Besides ain't there already some very good standards in effect? The National Fire Protection Association (www.nfpa.org) advises that each chimney receive a Level II inspection each time a residence is sold. Inspection levels are explained at http://www.csia.org/PressRoom/PressR...6/Default.aspx. It is also advised that this inspection be conducted by a chimney sweep certified by the Chimney Safety Institute of America (www.csia.org).The above is inserted into my reports with all fireplaces and is all I really need or want. "By three methods we may learn wisdom: First, by reflection, which is noblest; Second, by imitation, which is easiest; and third by experience, which is the bitterest." -Confucius Certified Master Inspector (2007) Member, International Assoc of Certified Home Inspectors (InterNACHI) Member, International Code Council (ICC) - Certified Residential Combination Inspector Square-One Inspection "Assurance begins here"
What role did the ESOP Committee play in this revision to NACHI's SOP? James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
If you want to compete with other inspectors then you will have to keep up with technology and so will that new company you will be working for (and the other one when this one does not work out) because you could not keep up with your competitors. Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
Who said it was revised?
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I don't know. I guess I was left out if they did.
Nick is announcing a SOP for chimneys and fireplaces this weekend. This is a revision to the SOP that does not include chimneys and fireplaces...unless NACHI will now have multiple "standards".
No one has announced a revision to the NACHI SOP.
What has been announced is an SOP for chimney inspections. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 7:11 PM |
| Understanding Chimneys and Fireplaces coursed approved by State of Illinois. | gromicko | Inspecting HVAC Systems | 2 | 4/14/08 8:51 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 9:16 PM |
| 2006 IRC Chapter 10 for Chimneys and Fireplaces Online: | homebild | Inspecting HVAC Systems | 0 | 6/18/07 11:27 PM |
| QOD- 12/22/2006 ( Chimneys & Fireplaces ) IRC 2003 | pabernathy | Inspection Question of the Day | 19 | 12/30/06 2:56 PM |
