Saw this in a newer (2004) condo building. In one unit only, rear bedroom master bathroom basin. It was a double basin vanity, but only one of the basins displayed this.
Supply (from valve to faucet) were steel tubing and the drain was steel. There was a green pateena on the supply pipes and the drain had green and black. The hinges for the door also appeared to be corrosed, but not with rust. No Chinese drywall (not used around here) and only one of the two basins were affected. Any ideas? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
May have been keeping corrosive are caustic supplies under that sink.
Any other sinks/drains this way? Could be storage of epson salts and combination of high moisture.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
I was thinking stored chemicals with the hinges like that and no visible damage to the cabinet or walls. Looks like a new tail piece, but can't get over those hinges.
Fort Worth Home Inspector Dallas Home Inspector |
Comet or any other Chlorine based household cleaners in the cabinet
Will,
was the bottom of the cabinet wet or was that dirt? 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Epson salt would absorb moisture. I agree that it is likely due to stored chemicals under the sink.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
The floor of the vanity was not wet when I inspected it and no deformation.
I am leaning towards a chlorine material. That would explain the green corrosion on the steel. I was confused because green is usually copper oxidation. Maybe some chlorine based drain cleaner or comet that got wet and the chlorine gas was released. Single guy in the unit and you know how they can be. Thanks. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
likely a product containing chlorine bleach stored under the sink
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Chlorine product is my guess - Chlorine from pools often corrode brass door hardware in the immediate vacinity, and rust metal doors and hinges. Something stored under cabinet with chlorine. could even be some 409 with bleech sprayed under cabinet to kill some fungus growth and not wiped off.
Most bathroom cleaners contain bleach (chlorine).
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Dishwasher air gap | bforeman | Plumbing Inspections | 13 | 2/26/10 5:12 PM |
| Water supply pipes and drain pipes running through return air ducts? | aharper1 | Inspecting HVAC Systems | 3 | 9/26/06 12:09 PM |
| supply in slab or walls? | jeubank | Plumbing Inspections | 1 | 7/8/06 10:36 AM |
| Lead drain and supply | cbuell | Plumbing Inspections | 9 | 2/28/06 2:45 PM |
