My biggest fear in Home Inspection is missing a bad deck.
I find most decks are not built properly and I look hard and make sure I miss nothing . We had one in Canada let go a few years ago with a lot of very important people on it and there was many seriously hurt. Michael Leavitt has started a new web site on decks have look you will learn a lot . Information on the deck that fell today in Virginia is on it already . DECK FAILURE DIRECTORY The message is ready to be sent with the following file or link attachments: Shortcut to: http://www.deckfailure.com/Failures.html Cookie |
Roy
thanks for the link good stuff |
Here is a site with info on how to build one correctly etc...
http://www.pahi.org/how_to_build_a_r...tial_deck.html B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Many "deckaroos" are cutting corners by nailing the header to the home exterior instead of bolting it.
With wrong size hangers to boot. ha. ha.
Nice pick up Peter. Looks like a crack in the foundation too. Hope the water proofing is below grade and adequate. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Nice sites guys...
Here's a deck that I found which had NO LEDGER BOARD whatsoever. It was attached to the lower 1/2 inch wood trim below the siding. Nice connection ayyy? "click to enlarge" Attachment 14523 Last edited by dvalley; 10/7/07 at 4:40 PM.. |
I had an inspection a couple days ago where only lags were used in areas I thought through-bolts should have. Areas of wood were separating with age, and needed tightening. I felt bad for 'flagging' concerns about a year old deck.
tom |
Another good article by Dek-Lok.
![]() ![]() ![]() Join Our DeckLok Newsletter! Click Here ![]() ![]() ![]() ![]() ![]() ![]() Store Locator >> Choose State Alaska California Colorado Connecticut Hawaii Illinois Iowa Kansas Kentucky Maine Maryland Massachusetts Michigan Minnesota Missouri New Hampshire New Jersey New York Nevada North Carolina North Dakota Ohio Oregon Pennsylvania South Carolina South Dakota Vermont Virginia Washington Wisconsin Canada ![]() ![]() ![]() DeckLok in the Press Back to the main In The Press Page Responding to Deck Failures Dec 2006 DeckWorld Magazine BY JANET ARDEN A deck failure can be as simple as a board that gives way or a sag that develops at one corner. It can also be as dramatic as the whole structure pulling off the second story of a house. You've seen the headlines and heard the news reports: A deck on a house in the 800 block of South Elm collapsed in the midst of a 30th anniversary party Sunday afternoon, sending five guests to the hospital with various injuries, none serious.The good news, of course, is that no one was seriously hurt. Unfortunately, that's not always the case. Of the deck collapses that were reported in 2006, 94% resulted in personal injuries. The actual number of deck failures is very difficult to know. Many deck failures go unreported because emergency crews were not summoned or the deck was not occupied at the time it went down. Additionally, decks that were clearly unsafe and were repaired or replaced before they collapsed are not recorded either. DeckWorld talked at length with Michael Morse, founder and president of DeckLok. Morse has been studying deck construction, building codes, and ways of developing a failure‑proof system for almost 25 years. Morse points to studies that show over 90% of deck failures are linked to a failure in the connection between the house foundation and the deck. Metal fasteners (whether they are bolts or nails) embedded in wood depend on the resistance of the wood fibers to hold the screw or nail in place, attaching the deck ledger to the house. But this assumes that both the fasteners and the surface they are gripping have the appropriate construction integrity. For starters, these same metal fasteners offer a pathway for water and then rot in the wood they are supposed to be holding. Seasons of freezing, thawing, and heat cause wood to dry, split, or even rot. Screws may loosen or pop out. Nails provide a much weaker connection to begin with and are more susceptible to popping. As Morse points out, it only takes a slight shift in the surface to begin a lateral pull on nails or screws. For example he points to how easy it is to remove a nail from a piece of wood, once it has started to withdraw. The lesson here, he says, is that once fasteners start to pull out, it does not take much for them to pop the rest of the way. What about the building code? According to the International Code Council (ICC), for the most part, "there are no prescriptives for decks in the International Residential Code. They would be treated as floor construction and would follow Chapter 5 of the IRC especially the floor joist spans table." Specifically, the 2006 International Residential Code, R502.2.2 Decks, stipulates: "Where supported by attachment to an exterior wall, decks shall be positively anchored to the primary structure and designed for both vertical and lateral loads as applicable." It goes on to describe attachment methods and structural supports. At its recent 2006 hearings in Orlando, the International Code Council Code Committee adopted a prescriptive method for attaching the deck ledger to the house, but it does not specify which part of the house this is. It even specifies the number and placement of bolts. Morse points out, however, that most decks are inspected the day they are complete - when the materials are new and they have not been subject to weather or weight. The damage comes when this same structure has been left in the elements - wet, cold, snow, heat‑for a decade or two. By Morse's definition, a successful deck is one that remains structurally sound throughout the service life of its wood. Engineering for decks, he says, needs to account for the fact that wood changes over time. Morse believes there are three key facts to keep in mind in preventing deck collapse:
There are no bad guys here. Morse is quick to praise the craftsmanship of deck builders. In fact, he says, most of them do a beautiful job - for 95% of the deck. He believes the last 5% - fastening the deck to the house - is where there's room for improvement. The following specifications regarding decks is from the 2006 International Residential Code:Section R501.2 Requirements Floor construction shall be capable of accommodating all loads according to R301 and of transmitting the resulting loads to the supporting structural elements.R502.2.2 Decks.Where supported by attachment to an exterior wall, decks shall be positively anchored to the primary structure and designed for both vertical and lateral loads as applicable. Such attachment shall not be accomplished by the use of toenails or nails subject to withdrawal. Where positive connection to the primary building structure cannot be verified during inspection, decks shall be selfsupporting. For decks with cantilevered framing members, connections to exterior walls or other framing members, shall be designed and constructed to resist uplift resulting from the full live load specified in Table R301.5 acting on the cantilevered portion of the deck.Table R301.5states that decks must be able to support 40 pounds per square foot. Exterior balconies must support 60lbs per square foot. To learn more, please contact the Intemational Code Council, www.iccsafe.org © DeckWorld Magazine Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Good job Peter, and hope you are keeping busy. Stay in touch. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
80% of decks I see are not built correctly .
Please be carefull do not miss writing them up another deck collapsed last night two in hospital . --------------------------------------------------------------------- Another Collapse Two people were taken to the hospital after a deck in Brooklyn Park collapsed. 20-30 people were standing on a deck of a home Saturday night, when it fell out from under them. Two people were taken to the hospital for their injuries. Hospital officials have not yet revealed the condition of the two people who were injured. Police have not yet determined the cause of the collapse. The coverage from WCCO and Kare11 was very brief and fact based. The police was only source used in either story. Using the police as a source is intelligent because they do research similar to that of a reporter so the information is pretty reliable, but I would have loved to hear from one of the victims. The sources were authority figures. ............ Cookie |
Check out the size of the screws (not bolts) securing this deck ledger to the house. How 'bout the mini joist hanger. I also called for an evaluation of the 4x4 posts without bracing.
“The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 10/7/07 at 9:37 PM.. |
Joe;
Are those tapcons? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
arussell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I asked the same question when I saw the 1st pic. If you look in the upper left corner you can see what appears to be concrete, so I beleive they are (plus being blue as tapcons are). My real concern, as Joe pointed out in the 3rd pic using too small of a hanger, but also using regaular common nails to attach the hanger and the gap in the ledger board (3rd pic) that the joist is so nicely covering up. That must be a weep hole for the deck! Joe Quote:
![]() ![]() alan |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Deck joist blocking/bridging | jbancroft | Structural Inspections | 7 | 10/4/07 9:16 AM |
| Deck Question | nishanf | Exterior Inspections | 22 | 6/2/06 6:41 AM |
