Can anyone explain to me how to properly change a single-pole dimmer switch with a single-pole switch. Thanks.
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Turn off power to that circuit. Remove installed switch and replace with new switch. They are wired the same.
I wasn't sure 100%. Thanks.
Only difference is dimmer switch will probably have lead wires that you'll connect to house circuit using wire nuts that came with switch instead of connecting at termination screws on side.
And the great think about a standard switch is...........You can't get it wrong no matter how you wire it!!!!!!!!!!!!!
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
How can you inspect the electrical system of a home when you don't even know how to install a simple switch? Un fu#@%*ing believeable!!!
| single circuit wired from one pole of appliance breaker OK? | fbartlo | Electrical Inspections | 5 | 7/16/10 10:56 AM |
| Screws showing hot on a dimmer switch. | kluce | Thermal Imaging, Infrared Cameras & Energy Audits | 17 | 6/11/09 4:43 AM |
| fAN ON DIMMER SWITCH? | mjones6 | Electrical Inspections | 11 | 9/14/08 4:19 AM |
| Dimmer switch fan control | jkogel | Electrical Inspections | 4 | 8/29/08 8:42 PM |
