Old 8/24/10, 2:40 PM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Default Double hung window
I have never actually seen one installed like this before.
Frank Magdefrau
Certified Master Inspector
DeSoto Home Inspection Services
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/24/10, 2:52 PM
Default Re: Double hung window
Matches the Masnonry Frank
Old 8/24/10, 5:02 PM
dquigley's Avatar
dquigley dquigley is offline
Please Note: dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Instant horizontal slider, bet its really watertight since it doesn't have proper bottom track with weep holes
Old 8/25/10, 12:43 AM
To me. This was not a builders mistake, this was a corner cutter plain and simple.
Frank Magdefrau
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
Old 8/25/10, 2:22 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
...YIKES! ...
Old 8/25/10, 8:31 PM
George A. H. Luck's Avatar
George A. H. Luck George A. H. Luck is offline
Maybe the house fell over after installation?
Old 8/25/10, 9:05 PM
dquigley's Avatar
Rotate the photo - its fine
Old 8/25/10, 9:23 PM
You're right Dennis, looks lot better.
Old 8/28/10, 7:11 PM
Tim Spargo's Avatar
I was at a home inspection... home was foreclosed on then finished by *others*
3 Bathroom windows, 2 bedroom and the Laundry Area all had *Hung Type* windows that were turned sideways into XO's and/or OX's
I wrote up the defect.... few days later the phone wrang with the seller telling me how many people were up in arms, as "The window is basically the same, just makes it a little more difficult to operate"
I tried explaining position of weep holes / drainage etc.. this fell on deaf ears
I was informed that if I was incorrect, I would be held accountable. I laughed at them
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 8/29/10, 2:32 PM
William J. Decker's Avatar
Typical. Sub-standard and unqualified builder makes a mistake and they want to hang the messenger.
"I didn't mess it up, I just reported that your people did."
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Need help flashing top of replacement window on brick wall !!! Bill Featherstone Exterior Inspections 5 6/26/10 11:25 PM
Broken exterior brick window ledge acatterton Structural Inspections 6 5/29/09 7:12 PM
Leak in bay window with copper roof hmiles Exterior Inspections 19 11/22/08 9:37 AM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 4 4/23/07 8:31 AM
Window installation jmichalski Exterior Inspections 17 1/24/06 10:42 PM
